Could anyone please tell me why "Video to Video" (converting software) doesn't fully convert all of the video files added to be joined as a single file?. I have added a number of .mts files (around a dozen), with sizes varying from a few mbs to over a hundred. I also included some smaller MPEG4 files, totalling to 3.88GB in size as a direct stream copy. However, once completed I noticed that the file sizes are noticeably smaller (which shouldn't be the case) and noticed it is missing a number of files that I added, including the MPEG4 files. The final outputed file came to 2.45GB
I have enough space on my HDD. Does anyone know what could be causing this?, or is it that the program cannot convert so many files or so large a file size in one conversion?.
I've not used it. But most programs which will combine multiple files into a single file, often choke or not work if the input files are not the same resolution or have the same audio format. Just something to look at/test.
Google is your Friend -
I never had a problem with join ing videos with Video to Video. As stated above, they must have the same file structure or else!
Video to Video is an excellent program. I wish it was further developed.
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 18:58 -
Synchronize video from 1.video and sound from 2.video using compare videos
By ad48 in forum EditingReplies: 0Last Post: 3rd Apr 2015, 06:18 -
Video Production: video overlay in real time over existing video
By tobyoneknobi in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2015, 08:11 -
How to cut any video with the free Video to Video Converter
By Baldrick in forum User guidesReplies: 12Last Post: 26th Apr 2014, 06:31 -
Best Application to capture video from Component/S-video video inputs
By techspark in forum Capturing and VCRReplies: 17Last Post: 8th May 2012, 16:09
