There was an old thread here on VideoHelp on this matter, suggesting AVIdemux or VirtualDub as the best options to do it.
I choose VD because it was mentioned that joining would be done with no re-encoding, so I went for that.
My first try went perfect, and I joined three files in one.
To help me I found this guide:
http://www.afterdawn.com/guides/archive/virtualdub_join_avi.cfm
Now there are two questions:
1) The guide says to go to the last frame in the file. In this file the last frame was white, so I picked a black one. Is that alright?
2) Can I choose another point at the end of the file? It looks like it, from what I describe above, but I would like to be sure
Step three of that guide is unnecessary. File -> Append AVI Segment always appends at the end. It doesn't matter where the slider is.
OK, that means I can't use that joining to cut titles off from the end of episodes 1 and 2?
Sure you can. You could simply append first then use the cut tool to remove the parts you don't want. Or you could open the first video, use the cut tool the remove the end of the video, then append the second video.
Keep in mind that VirtualDub can only cut on keyframes when you use Direct Stream Copy mode.
Joining multiple avi files
By jasonjdking in forum Newbie / General discussionsReplies: 2Last Post: 28th Oct 2015, 17:00 -
Joining TS files, compressing the size but keeping quality - Noob Help!
By OneVibe in forum EditingReplies: 10Last Post: 24th Jun 2015, 03:36 -
Program for joining AVI files - not VideoDub
By assburger in forum EditingReplies: 8Last Post: 7th Oct 2012, 21:12 -
How should I encode this 8GB AVI file while keeping its image quality?
By hkBattousai in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2012, 17:23 -
Best way to play 3D bluray video files while keeping the best quality
By mad555 in forum Media Center PC / MediaCentersReplies: 5Last Post: 16th Feb 2012, 03:48
