http://www.telemann.com
hipix dtv-200
$400
saw that earlier and i'm wondering if anyone has one. I saw some people over at avsforums.com do. What i'm mainly wondering is I know that video is takin from the mpeg2 stream itself and not reencoded to huffy or mpeg 2 or whatever. so you don't loose quality. now a 1920x1020 sounds good to me. What i'd like to know is how is do you like it and has it worked good if you have one. and say you wanna run your captures through cinema craft to make them fit on a cd. So around 2500kbit. How would you go about doing that with the 1minute files it makes.
140mb per min and for 60min show there would be 60 of them. Now ofcourse you want to edit out commercials. So how would you go about doing that and then encoding it in cinemacraft?
Results 1 to 1 of 1
HDTV ATSC Tuner Quality
By sambat in forum DVB / IPTVReplies: 5Last Post: 24th Nov 2011, 15:57 -
Converting HDTV recordings to MKV - quality issues
By Bully9 in forum Newbie / General discussionsReplies: 24Last Post: 29th May 2010, 12:31 -
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 31st Jan 2010, 23:23 -
Help on how to convert HDTV to DVD Resolution for the best quality
By Kid Chameleon in forum DVB / IPTVReplies: 62Last Post: 5th Apr 2008, 06:31 -
Have you tried DivX files on LCD HDTV? How was quality
By Mike_B1122 in forum DVB / IPTVReplies: 5Last Post: 3rd Aug 2007, 20:49
