Dear forum members
I have downloaded a video from the following url:
https://tv.jw.org/#en/video/VODBible/docid-502017151_1_VIDEO
In regard to other videos previously downloaded from this website I have been able to make them "hard" or permanant using Handbrake - just by loading the file and in the subtitle tab selecting the "burn" option before processing
However with the video above, I find handbrake fails to do the job with the subtitles.
Please can anyone kindly advise what may be the problem and if possible whether there is a solution suggested.
Thanks and best wishes
Ian
ian c
I downloaded the latest 32 bit 1.0.2(2017012200) and it worked fine. I noticed it selected Forced and grayed it out as well as burnin but the subs
appear to be fine and hardcoded in the result. -
Dear Sir (Budman)
Thank you for your kind effort and reply.
Following your advice I downloaded and installed the latest version. I am happy to report that it did work !
For some reason the earlier version, which had been working previously with videos from this website, was no longer doing the job.
I am not sure why this is. However I am pleased to advise of the happy outcome: Thank you once againian c
"Soft-subbing" video with ffmpeg?
By Unknown01 in forum Newbie / General discussionsReplies: 8Last Post: 28th Feb 2016, 09:46 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
"Any Video Converter" flips my subtitles upside down. Fix?
By chapelhillfiddler in forum SubtitleReplies: 3Last Post: 20th May 2013, 11:32 -
AviDemux "ripped" subtitles to SRT perfectly ... _except_ for duration ...?
By Diana (Cda) in forum SubtitleReplies: 14Last Post: 15th Feb 2013, 17:27 -
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 18:35
