I have a Panasonic HC-V720 Camcorder, which I managed to get slightly wet. On turning on the camera the lens cover has opened, and a steady amber light now appears on the rear of the camera, also there is a red light on by the SD card aperture. I have allowed the camera to dry (10 days now) and it is still not functioning. I have searched the instructions and cannot find any amber / orange light error conditions mentioned. Is there any reset / cure for this.
Thanks.
Removing all power for about 1 minute should reset the camera. That lamp on the back is a status indicator. If it shows Caution I would say the camera is not passing its power-on test. Probably some contacts shorted when the camera got wet and caused permanent damage.
laptop keyboard light
By vhelp in forum ComputerReplies: 3Last Post: 3rd Dec 2016, 14:20 -
Green screen - two light set up?
By worldofwigan in forum Newbie / General discussionsReplies: 1Last Post: 23rd Nov 2015, 08:27 -
Light Alloy v4.7.5
By TheDutchJewel in forum Software PlayingReplies: 33Last Post: 29th Sep 2015, 15:27 -
HP Computer: Amber Light & Beeping
By Tom Saurus in forum ComputerReplies: 11Last Post: 20th Apr 2015, 10:50 -
Error Code: C111.1 for Panasonic DVD DMR-EZ48V ??
By videoit in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2015, 18:23
