  1. I wasn't sure which sub-forum would be best, but to me this does fall under "Latest Video News".
    NetFlix has created a 12 minute short movie and released the assets under a Creative Commons License:
    http://variety.com/2016/digital/news/netflix-meridian-imf-tools-open-source-1201859416/
    This film is unique in that it's purposely crafted in such a way as to be a torture test for encoding algorithms, hardware and work flows.
    I downloaded the 90gb test file and it lives up to its purpose, one interesting thing I learned, opening the file with Media Info reveals the following:
    MERIDIAN.mxf
    Format : MXF
    Format version : 1.3
    Format profile : OP-1a
    Format settings : Closed / Complete
    File size : 88.5 GiB
    Duration : 11 min 58 s
    Overall bit rate : 1 058 Mb/s
    Encoded date : 2016-09-09 11:29:39.012
    Writing application : Colorfront Transkoder 2016.0.0.29813.0
    Writing library : Microsoft Windows 7 Professional Service Pack 1 (Build 7601) 2.7.3.0.1
    Video
    Format : JPEG 2000
    Format profile : 206
    Format settings, wrapping mode : Frame
    Codec ID : 0D010301020C0100-040102020301017F
    Bit rate : 1 058 Mb/s
    Width : 3 840 pixels
    Height : 2 160 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 (60000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:2
    Bit depth : 10 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 2.128
    Stream size : 88.5 GiB (100%)
    Title : Picture
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Other #1
    Type : Time code
    Format : MXF TC
    Time code of first frame : 00:00:17;12
    Time code settings : Material Package
    Time code, striped : Yes
    Other #2
    Type : Time code
    Format : MXF TC
    Time code settings : Source Package
    So, NetFlix uses Win 7 pc's and they use something called Colorfront Transkoder, googling it brings us to the following:
    http://www.colorfront.com/index.php?page=SOFTWARE&spage=Transkoder
    It looks like they use HP based workstations, and reading through the docs it seems evident that they rely on gpu acceleration because they claim 100+ fps 4k hevc encoding and they claim that their solution makes use of multi-gpu setups.
    As an interesting side note, I've been playing around with NVENC on Ubuntu via a self-compiled ffmpeg build and while reading through all the docs on NVIDIA's website on NVENC I came across a very interesting bit of info: NVENC, is not entirely based on a dedicated hardware block, it's actually partially powered by CUDA!
    Additionally, since some of the complexity estimation is performed in CUDA, there may be some performance impact when temporal AQ is
    enabled
    http://developer.download.nvidia.com/designworks/video-codec-sdk/secure/7.1/01/NVENC_V..._ProgGuide.pdf
    You can find it under the Temporal AQ section.
    Even more interesting, I found the following under "Motion-Estimation-Only Mode":
    NVENC can be used as a hardware accelerator to perform motion search and generate motion vectors and mode information. The resulting motion vectors or mode decisions can be used, for example, in motion compensated filtering or for supporting other codecs not fully supported by NVENC or simply as motion vector hints for a custom encoder. The procedure to use the feature is explained below.
    So, if one where so inclined, one could create a xvid, x264, or x265 fork where the software motion vector algorithms were removed and instead used a NVENC as a brute force approach.
  2. Very nice. For anyone wanting short video test material, the main directory holds 'Derf's Test Media Collection'. A selection in various flavors.
    https://media.xiph.org/video/derf/
    enabled
    That is interesting...
    Your pdf link doesn't work for me (maybe limited by session id) , and the first few google entries had the wrong older version. The one directly from searching the site is dated Nov 2016. Anyways here is the relevant excerpt
    Although the core video encoder hardware on GPU is completely independent of CUDA
    cores or graphics engine on the GPU, following encoder features internally use CUDA
    for hardware acceleration. Note that the impact of enabling these features on overall
    CUDA or graphics performance is minimal and this list is provided purely for
    information purposes.
    Two-pass rate control modes for high quality presets.
    Look-ahead
    All adaptive quantization modes.
    Encoding with inputs in RGB formats.
    And that would be awesome if someone could program some ME filters using NVEnc , or if you could utilize the vectors in other applications . I don't know how "good" the ME component is or what algorithms are used, but it still could be useful
  4. I'm attaching it here.
  5. Dinosaur Supervisor KarMa's Avatar
    It's 4K yet still BT.709 and not BT.2020. Interesting. And with the JPEG 2000 it looks like it's designed to play in a digital movie theater. Nice share, thanks.
