When you install a program such as VLC Player or Pot Player they will install codecs and/or LAV filters and even FFMPEG. Are these codecs and filters used by other programs such as MKVToolnixGUI and AVIdemux? I know that both these video players support many types of video formats and because of that I'm assuming they install a large library of codecs and/or LAV filters. Im also assuming more then are installed when MKVToolnix and AVIdemux are installed. Do I need to install CCCP or K-lite to benefit my video editing software or will they be able to take advantage of the codecs and filters that were installed from the video player?
	Most of these add the add codecs for internal use...
 AFAIK You cant use these codecs for other apps.
 If you want LAV, install it separately
 MKVToolnixGUI does not have any codecs in the installation
 re: Do I need to install CCCP or K-lite to benefit my video editing software or will they be able to take advantage of the codecs and filters that were installed from the video player?
 -its a personal preference
	Players based on libavcodec in different degrees were made with the purpose to be independent of "codecs" (which usually means "DirectShow filters" today) being installed into Windows. Some versatile players (e.g. MPC-HC, MPC-BE) may use Windows installed DirectShow filters and possibly even VfW codecs when their internal decoders and splitters (LAV Filters with direct API access, not using DirectShow) can't handle a format; other compact players (like VLC) will not use anything else than their internal libraries.
	System codecs (i.e. any codec registered in Windows) can be used by different applications (some commercial codecs may have certain limitations to cooperate with other than selected applications) - generally you can control how system and application will use codecs by changing priority (merit) of codec - those one with higher merit will be preferred by system and applications using system.
 VLC doesn't use system at all (as VLC is multisystem).
 https://msdn.microsoft.com/en-us/library/windows/desktop/dd940318%28v=vs.85%29.aspx
  Dates of LAV filtersBy jgg in forum Software PlayingReplies: 6Last Post: 27th Jan 2016, 15:02
  Help with Potplayer with LAV Filters + receiver?By Fabulist in forum AudioReplies: 2Last Post: 22nd Oct 2015, 04:06
  Do I need LAV filters?By Yanta in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jan 2015, 05:01
  Potplayer crash with lav filters.By mzso in forum Software PlayingReplies: 2Last Post: 18th Feb 2013, 22:07
  Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 19:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
