I have a number of cartoon files in MKV format where I only want to keep chapters 1, 2 and 4, which is to say I want to remove Chapter 3. When I load such a file into the MKVToolNix input tab, the "tricks, chapters and tags" box reads "4 entries" under Chapters, as expected. Switching to the output tab, the only real choice available to me seems to be selecting the "splitting" (before chapters) option and re-merging the three resulting pieces. Is there an easier way to do this?
You want to completely remove the chapter (i.e. not just the chapter mark metadata but the actual video+audio from the timeline)? That seems impossible indeed unless you manually use "by parts based on [...]". You could make a feature request to the author. Seems strange that it isn't supported for "by parts" splitting.
Thanks. I finally just wrote a batch file splitting the files into all chapters and then reassembling only the ones I wanted.
Wallywalters: you mention the following
"Thanks. I finally just wrote a batch file splitting the files into all chapters and then reassembling only the ones I wanted."
Any chance you could share that script with us?
Using MKVtoolnix Chapter Editor
By hurricane1951 in forum EditingReplies: 25Last Post: 13th Feb 2023, 07:56 -
Mkvtoolnix Batch Remove Audio OSX
By neostylez in forum Newbie / General discussionsReplies: 13Last Post: 27th Dec 2016, 09:42 -
MKVToolNix GUI muxing - problem with chapter
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jun 2016, 23:18 -
How do I remove the first chapter from a movie?
By mw8t in forum EditingReplies: 4Last Post: 23rd Jan 2015, 19:15 -
How to remove one audio channel from a single audio track?
By helloguys in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2013, 13:35
