i have a movie that i wanna convert with tnmpg and i used virtual dub to get the audio file and when i put convert them togethor the sound is off by a second in some parts what program and how can i change it please messsage back thanks
The Wiz
it was probably in sync and out of sync at times huh? that happen to me before. Did you just open the avi with virtual dub and save wav.. then use that wav in tmpg? If so, thats probably the reason why. You need to uncompress the wav, you can do that with winamp, thats what I do, just open the wav with winamp, press stop, then press CTL P to open the preferences. On the left where it says plug ins, goto Output, and double click on nullsoft disk writer plugin, choose a directory you want to store the uncompress wav. click ok then close the preferences. now just press play and it will uncompress the wav, (make sure you don't have winamp on repeat or it will keep repeating.) after it's done, press CTL P again to get back to the preferences, double click on Nullsoft Directsound and click ok, and close winamp. Now use the new wav file u converted with winamp instead of that other file
i'm gunna try that in a few minutes thanks for the feedback i'll let u know if that is the problem but i think it is
LataThe Wiz -
You can do that in Virtualdub a lot easier,
Open file > Audio > Full Processing > No Compression > file > save as wav
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 06:36 -
RipBot264 Audio Problem (no audio)
By fefalas in forum Video ConversionReplies: 9Last Post: 8th Apr 2011, 10:39 -
Audio problem
By Goten in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2007, 21:44 -
problem with Audio
By cgguy in forum AudioReplies: 1Last Post: 14th May 2007, 06:48
