I'm trying to find this program that lets you do extensive editing of a VHS, were you can drag and drop from a video editing program like Abobe Premiere to the external program which imports it all into images, so then you can work frame by frame to remove any artefacts on the picture. It has a clone stamp feature allowing you to paint over the artefacts by overlaying the previous or following frame were the picture is clear, then you can mask over the white specs, streaks or whole big chunks of tape damage to clean the picture up.
I came across a really good video about it on Youtube a few days ago, but have forgotten the name of it so now can't find it! I was very impressed by it. Anyone have an idea what this program may be?
				Results 1 to 11 of 11
	Just by chance i came across it again! Just as i had given up looking for it.. all day
 The program he was using is GIMP.
 https://www.youtube.com/watch?v=gY85jhP6V-0
 Looks like a great method to getting rid of VHS flashes, defects otherwise something automatic processing couldn't handle.
 That PFClean program looks excellent, though costs a bomb! Apparently used by film studious for restoring their old features. I've heard AviSynth is good for removing things like comets, but you'd have to get familiar with using scripts. Is it hard to do?
	Yes, particularly for what you want to use it for. But it's worth it and beats working on individual frames any more than you have to. Most of the work can be done using filters. Some can't be fixed and have to be edited in a photoeditor. Although I have Gimp installed, I do my frame editing in PhotoFiltre:
 https://photofilltre-portable.jaleco.com/
 And then I use AviSynth to replace the bad frames with the edited ones. At the risk of pimping my own YouTube channel, here are fairly easy-to-do examples of what can be accomplished using AviSynth with no individual frame editing at all:
 https://www.youtube.com/watch?v=c4gqBI7TicE
 https://www.youtube.com/watch?v=7N9ulGfU0OE
 https://www.youtube.com/watch?v=kmjxa60gTLE
 The second one was made from a VHS tape I captured. The third one is from a retail DVD made from a tape capture. I don't know the original source of the first one, although it's also from a retail DVD.
	Ah, i'll treat it as a college course and start learning all the basics then  It will save alot of time. I won't be capturing my videos until i've built my new pc first, so should be a few weeks or so. It will save alot of time. I won't be capturing my videos until i've built my new pc first, so should be a few weeks or so.
 If it all becomes too much i'll revert to more user friendly methods.
 Wow great results you got with it from those videos. Puts the home video distributors to shame!
	There's no single script. It takes me roughly 40 hours and three complete frame-by-frame goings over to clean up the crappy tapes and DVDs with which I work. There are many scripts used during the entire process, frequently as many as 20 different scripts to perform different filtering or work on different parts of the films.
 For stabilization I use Stab, for noise clean up and general cleaning, RemoveDirtMC and FFT3DFilter. For frame artifact fixes, FixBadFrames, ReplaceFramesMC, FreezeFrameMC and BadFrames. For levels, luma, and contrast fixes, Levels, YLevels and Tweak. And other stuff. It's all grunt work fit only for the most anal retentive with way too much time on their hands.
 If you'd like some of the filters, just ask.
	Yup wrote excellent scripts to remove these dropouts (either black or white horizontal lines), see see here for example, Sometimes it's not enough hence the use or removespotsmc, degrainmedia, removedirtmc and other filters *** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
	It’s 2020 now
 Is this filtering software available for a newer Mac?
  I want to remove these white spotsBy TeNSoR in forum Newbie / General discussionsReplies: 10Last Post: 24th Dec 2016, 18:48
  How can I remove the yellow spots from the video?By TeNSoR in forum Newbie / General discussionsReplies: 6Last Post: 6th Jun 2014, 09:00
  How can I remove the dirt and green spots from this video?By TeNSoR in forum Newbie / General discussionsReplies: 6Last Post: 23rd May 2014, 10:14
  How to remove scratches and spots in videoBy arun28 in forum EditingReplies: 8Last Post: 24th Feb 2013, 10:25
  white streaks, black streaks, comets, dropoutsBy jmac698 in forum Capturing and VCRReplies: 6Last Post: 8th Mar 2012, 09:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
