When I'm at Twitter, I always get the message "The media cannot be played." I have installed AC3, K-Lite Codec Pack, DivX, XVID, MPCHC, VLC Media Player, AviSynth 2.5, DVD Decrypter, FairUse Wizard 2, Gabest VobSub, Movie Maker, AVI-MPEG-ASF-WMV Splitter, Easy Video Splitter, MPEG4Modifier, MPEG Streamclip 1.2, VirtualDub 1.9.5 x64 (AMD64), and other joiners/splitters. I think I have all codecs installed.
When I open the Twitter console, I get this:
Cannot play media. No decoders for requested formats: video/mp4; codecs="avc1.42E01E mp4a.40.2", video/quicktime; codecs="avc1.42E01E mp4a.40.2", video/x-m4v; codecs="avc1.42E01E mp4a.40.2" 825032700172107776
Content Security Policy: Directive ‘frame-src’ has been deprecated. Please use directive ‘child-src’ instead. (unknown)
Content Security Policy: The page’s settings blocked the loading of a resource at self (“script-src https://twitter.com http://localhost:* http://localhost.twitter.com:* https://*.twitter.com https://*.twimg.com https://vine.co https://*.vine.co”). Source: onfocusin attribute on DIV element. 825032700172107776
HTTP “Content-Type” of “application/x-mpegurl” is not supported. Load of media resource https://video.twimg.com/ext_tw_video/825032628646600704/pu/pl/PXVd6EwXPhaTM-rW.m3u8 failed. 825032700172107776
Cannot play media. No decoders for requested formats: video/mp4; codecs="avc1.42E01E mp4a.40.2", application/x-mpegurl 825032700172107776
I have Windows XP X64 installed.
Can anyone help? What do I need to install, where do I get it?
Thanks, Hart
Results 1 to 10 of 10
Since the https://video.twimg.com/ext_tw_video/825032628646600704/pu/pl/PXVd6EwXPhaTM-rW.m3u8
is the playlist for the video you want to watch, I can only assume the browser you are using doesn't play HLS streaming
hence the ((HTTP “Content-Type” of “application/x-mpegurl” is not supported) message), at least, not from that source.
The link itself, reports as a 'stream not found' when I try to play it. The link may be dead.
EDIT: On a hunch I came back after checking your operating system. Not good news for you.
I suspect you're using Firefox. Please read:
https://support.mozilla.org/en-US/questions/1135096
Most confusing is the Microsoft site which lists XP (with service pack 3) as acceptable system requirements
http://www.microsoft.com/en-us/download/details.aspx?id=8279&e6b34bbe-475b-1abd-2c51-b...34bcdd6d2=True
Perhaps you need .NET Framework, or you have the wrong Framework and Visual Studio combination (see link for details).
I would definitely look to upgrade to at least Windows 7.Last edited by transporterfan; 28th Jan 2017 at 11:41.
Hi Transporterfan,
Thanks for responding.
Since I have the same problem playing all videos, I think it may be Firefox (which I forgot to mention that I use) that's causing the problem. IE x64 doesn't work either though. I installed QuickTime but it didn't help either. My daughter has a Mac laptop and they play on it. I'm surprised Twitter makes it so difficult to play videos on it's site.
Thanks again, appreciate it.
Hart -
All may not be lost!
Download and try installing the sdk (all components).
Note::: it is IMPORTANT you delete any installed Microsoft Redistribution C++ 2010 packages. If you don't, the install will fail...every time.
It will install its own C++ 2010 packages. After you (hopefully manage to) install the sdk, you can update them again to the latest version if you wish or need to.
Good luck. -
Should I uninstall Redistribution C++ 2010 and then install sdk from here: https://www.microsoft.com/en-us/download/details.aspx?id=13521
Right now, I have installed Microsoft Visual C++ 2010 X86 Redistributable 10.0.40219 and
****************************************Microsoft Visual C++ 2010 X64 Redistributalbe 10.0.30319
Plus I have C++ 2005 Redistributable
*****************C++ 2005 Redistributable (X64)
*****************C++ 2008 Redistributable X86 9.0.30729.4148
*****************C++ 2008 Redistributable X86 9.0.21002
*****************C++ 2013 Redistributable (X86) 12.0.30501
Which ones should I remove?
Oftentimes, I get things from MS for both X86 and X64 and I need them both.
HartLast edited by HartsVideo; 29th Jan 2017 at 00:42. Reason: I wasn't finished but accidentally clicked Save
Sorry, been researching this all day.
What I have discovered is this: don't bother with the sdk packages. I honestly don't think it will make a blind bit of difference.
It works for some on later operating systems, and there is an alteration to the about:config settings which work for others.
The fact is, it is the browser developers (slow to make changes) and Twitter (making changes without consideration for users) who are at fault.
Because your operating system is effectively defunct it will prove impossible to upgrade to the latest (or later) Firefox or Explorer
capable of processing HLS streaming. As far as I can see, your only hope is to use an older version of Google Chrome.
It has to be an old version because (same as other developers) they have dropped support for XP and Vista.
I am pretty sure Chrome Version 37.0.2062.120 will still work for you but to be safe use Version 36.0.1941.0 (Dev).
You can get it here http://www.oldapps.com/google_chrome.php
Sorry I can't be of more help. Hope it works out for you.Last edited by transporterfan; 29th Jan 2017 at 19:42.
Hi sysanin and transporterfan,
Thanks for your help. I tried All in One Runtimes but it didn't help. I also tried to install Google Chrome 36.0.1941.0 (Dev) but I got a message that said that "No update is available" and it wouldn't install.
I appreciate your thoughts.
Hart
Is it possible to view videos on a camera?
By YeshyyyK in forum Newbie / General discussionsReplies: 15Last Post: 23rd Nov 2016, 10:14 -
How to share, auto-sort, cache videos/photos offline view?
By riu1 in forum Video Streaming DownloadingReplies: 1Last Post: 13th Nov 2015, 03:03 -
720p and 1080p videos?:SRT files?: PS3 playback?: HD videos?
By vortun in forum Newbie / General discussionsReplies: 9Last Post: 4th Aug 2013, 10:22 -
how do i reconfigure default view in open dialog view to details ?
By vhelp in forum ComputerReplies: 11Last Post: 9th Nov 2012, 23:12 -
Software to list thumbnails of music-videos from many folders in sigle view
By DaveBG in forum Newbie / General discussionsReplies: 0Last Post: 5th Mar 2012, 14:55
