I develop a PHP code and count how much data was downloaded by the client. My code is working fine if someone directly requests my file from a browser. But if someone installs a Mozilla extensions like ‘’downthemall’’ and then the url is requested by that extension then it requests the file URL 4 times so I get the downloaded data 4 times. How do I fix this? The same happened when the user is using jDownloader software or any software.
PHP Code:<?php
function getMimeType($fileName)
$c_type_default = "application/octet-stream";
$content_types = array(
"exe" => "application/octet-stream",
"zip" => "application/zip",
"mp3" => "audio/mpeg",
"mpg" => "video/mpeg",
"avi" => "video/x-msvideo",
"mp4" => "video/mp4",
// echo isset($content_types[pathinfo($fileName, PATHINFO_EXTENSION)]) ? $content_types[pathinfo($fileName, PATHINFO_EXTENSION)] : $c_type_default;
return isset($content_types[pathinfo($fileName, PATHINFO_EXTENSION)]) ? $content_types[pathinfo($fileName, PATHINFO_EXTENSION)] : $c_type_default;
function output_file($file, $name)
This function takes a path to a file to output ($file), the filename that the browser will see ($name) and the MIME type of the file ($mime_type, optional).
//Check the file premission
if(!is_readable($file)) die('File not found or inaccessible!');
$size = filesize($file);
$name = rawurldecode($name);
//turn off output buffering to decrease cpu usage
@ob_end_clean();
include('../includes/configg.php');
// Start Code For Total Downloaded Data Size by The LoggedIn User
$user="select * from $TBusers where id=".$_SESSION['log_id'];
$result_user = mysqli_query($conn, $user) ;
$row = mysqli_fetch_assoc($result_user);
$lastsotrage = $row['down'];
$curr_date= $row['curr_date'];
$today_date= date('d-m-y');
$daily_downloaded_data= $row['daily_downloaded_data'];
if($curr_date != $today_date)
$update_curr_date="update $TBusers set curr_date ='$today_date', daily_downloaded_data =0 where id=".$_SESSION['log_id']; // Set Curr_date by Today Date For check Daily Downloaded Data Limit
mysqli_query($conn,$update_curr_date) ;
$daily_downloaded_data=0;
/*else
if($daily_downloaded_data>=(20*1024*1024*1024)){ // Check Daily Download Data Limit 20GB Exceed or not
header('Location: http://idownload.club/members/download.php');
exit;}
// required for IE, otherwise Content-Disposition may be ignored
if(ini_get('zlib.output_compression'))
ini_set('zlib.output_compression', 'Off');
header('Content-Type: ' . getMimeType($name));
header('Content-Disposition: attachment; filename="'.$name.'"');
header("Content-Transfer-Encoding: binary");
header('Accept-Ranges: bytes');
/* The three lines below basically make the
download non-cacheable */
header("Cache-control: private");
header('Pragma: private');
header("Expires: Mon, 26 Jul 1997 05:00:00 GMT");
// multipart-download and download resuming support
if(isset($_SERVER['HTTP_RANGE']))
list($a, $range) = explode("=",$_SERVER['HTTP_RANGE'],2);
list($range) = explode(",",$range,2);
list($range, $range_end) = explode("-", $range);
$range=intval($range);
if(!$range_end) {
$range_end=$size-1;
} else {
$range_end=intval($range_end);
$new_length = $range_end-$range+1;
header("HTTP/1.1 206 Partial Content");
header("Content-Length: $new_length");
header("Content-Range: bytes $range-$range_end/$size");
} else {
$new_length=$size;
header("Content-Length: ".$size);
/* Will output the file itself */
$chunksize = 1*(1024*1024); //you may want to change this
$bytes_send = 0;
if ($file = fopen($file, 'r'))
fseek($file, $range);
while(!feof($file) &&
(!connection_aborted()) &&
($bytes_send<$new_length)
$buffer = fread($file, $chunksize);
print($buffer); //echo($buffer); // can also possible
flush();
$bytes_send += strlen($buffer);
fclose($file);
$lastsotrage= $lastsotrage + $size;
$daily_downloaded_data+=$size;
$sql="update $TBusers set down =". $lastsotrage." where id=".$_SESSION['log_id'];
$sql2="update $TBusers set daily_downloaded_data = $daily_downloaded_data where id=".$_SESSION['log_id'];
$sql3= "update test set count=count+1 where id=1" ;
mysqli_query($conn,$sql) ;
mysqli_query($conn,$sql2) ;mysqli_query($conn,$sql3) ;
file_put_contents('data.txt', print_r($_SERVER, true), FILE_APPEND);
} else
//If no permissiion
die('Error - can not open file.');
//die
die();
//Set the time out
set_time_limit(0);
//path to the file
$file_dir=$_GET['directory'];
$file_name = str_replace("/", "", $_GET['file']);
$file_name = str_replace("\\", "", $file_name);
$file = $file_dir . "/".$file_name;
//Call the download function with file path,file name and file type
output_file($file, ''.$file_name.'');
Is there only a single file, or several versions of the file? DownThemAll scans a url for all files available on that page and allows the user to choose which file(s) get retrieved. Items such as images often show up twice (thumbnail and full size image). So it's likely related to how the objects are coded on the page.
Google is your Friend -
Downloader managers also use multiple file access to download faster, so while they may look as though they are downloading 4 times, in reality they are reading only a part of each accessed file in 4 'splits' or segments. I have no idea what the solution is, but I have seen many cyberlockers forbidding their use.
How to get playable url to vlc? See the url (uplync)
By bloodhod in forum Video Streaming DownloadingReplies: 3Last Post: 5th Jul 2016, 05:13 -
Windows® Phone 8.1 : Nokia Lumina 630 is hitting retail market soon
By enim in forum Latest Video NewsReplies: 13Last Post: 30th May 2014, 12:36 -
VOB2MPG Pro Feature Requests
By hurricane1951 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Dec 2013, 23:57 -
Editing for broadcast - tips on hitting these tech targets?
By bigass in forum EditingReplies: 17Last Post: 4th Oct 2013, 10:44 -
veehd requests
By hollow99fan in forum Video Streaming DownloadingReplies: 2Last Post: 30th Aug 2012, 16:24
