Results 1 to 14 of 14
  1. Hi there
    I'm writing/translating about Workflow of Gone Girl movie. but the are some jargon I can't understand.
    "The film was shot on a RED Dragon at 6k (6144 x 3072), ultimately to be used for a 5k extraction (5120 x 2876). The additional space was used for stabilization and re-framing\adjustment of shots in post production. The final film was delivered at 4K (4096 x 1706)."
    what does 5k extraction mean? can anyone exemplify that?
    Welcome to the Hotel California
  2. They use more pixels to accommodate loss for some video processing (call this crop - final viewport window will be smaller than input).
  3. Member Cornucopia's Avatar
    Exactly
  4. Originally Posted by pandy View Post
    You mean the DP frames the shot at 5K, but camera capture at 6K for some changes in post production?
    I mean cinematographer looks or considers the 5K composition...?!
  5. Please check these shots
    Feb 2008
    Poland
    Man, these shots speak for themselves. What don't you understand?
  7. 5k extraction only means part of the original shot is used in the final cut (mathematically 5/6 of of what was captured was used.) 5k out of the 6k
    only the center is extracted... the outer band is cropped out...
    As Pinto007 said these shots speak for themselves
  8. You need for image stabilizer pixels surrounding visible part of video and as such you need more pixels in source capture to crop visible area.
    This is common practice in video and cinema industry.
  9. I got it, but I was looking for an equivalence to translate 5K extraction.
    Thanks, everyone.
  10. image stabilized cropping?
  11. Originally Posted by teodz1984 View Post
    It can't translate into Persian I will write a description for that. something like...This (crop) or additional space was used for stabilization and re-framing\adjustment of shots in post production.
    In this case in our language, crop means frame.
    Thank you
  12. As a non English speaking person I love phrasal verbs , you might try phrasal verb to cut out, cropping a frame means to cut out a part of the frame, where you take away part of the top, right, bottom and left of the frame.
  13. to prune out
  14. Originally Posted by _Al_ View Post
    They captured at 6K, but finally cut out (cropped out) 1/6 of what captured and extracted to 5K.
    sounds right?
