  1. Anyone know the brand and model no for the attached pic?
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    If the door was flipped up it should say Panasonic. Just do a Google search for Super Drive VHS DVD recorder.
    Feb 2006
    Look on the back of the player, there should be a sticker showing
    The model number & manufacturer.
  4. I don't own this machine. I found the pic on the web.
  5. Definitely Panasonic, as hech54 said. Looks like an older model, circa 2004, probably DMR-E75-S:
    https://www.amazon.com/Panasonic-DMR-E75VS-Progressive-Scan-Recorder-Combo/dp/B0001WV6W8
    Since these are in a rack and numbered, its a cinch they've been used heavily for transfers, surveillance, or perhaps commercial tasks. If you're considering buying one, don't pay too much (anything more than $100 would be too much). Personally I wouldn't touch a 13 year old unit, but some people get lucky.
    It also depends on your intentions. It wouldn't be a good risk if you needed fully functional, reliable dvd and vcr. But if you just wanted it for a pass-thru signal conditioner connected between your VCR and PC capture device, its probably fine even if the VCR and/or DVD drive don't work.
  6. Thank you. Yea thinking of getting some cheap not working units for pass-thrus.
