Since the way interlaced displays work is we see the full "frame" thanks to us images remaining in our vision for a bit, wouldn't we still notice that the fields which are 1/60th of a second apart don't actually line up when things move in that span of time (I realize it would be different for stuff originally shot on film, since the frames are divided up into true half frames instead of fields)? Or is it because we don't perceive that so much when each field is only on the screen for 1/60th of a second?
				Results 1 to 13 of 13
	Because progressive display ignore time order for fields and display two fields from different time slots at once.
 Interlaced display can be simulated on progressive but usually it is better to deinterlace video than simulate interlace.
	Also, if you look closely at a CRT display you'll see that the size of the electron beam is nearly two lines thick. So the previous field no longer visible and is not black, it's simply overwritten by the current field.
	There is many factors involve in CRT resolution - electron beam can be bellow sub-micron (electron lithography is example), there is mask (grill) involved for colour displays, phosphor grain etc but some colour CRT's offered more than 2000 lines resolution and CRT's with microchannel plate and/or fiber-optic screen may offer even higher resolutions.
	who cares? CRTs have gone the way of the dodo and interlacing will too hopefully, but we apparently still live in a bandwidth limited world according to broadcasters.
	You actually notice nothing on a CRT interlaced display, not only because of persistence of vision, but because the "painting" of the picture by the scanning electron beam gun is continuous. That means that as the beam scans across the face of the tube, every moment in time is different. This is quite different from film or from a typical LCD TV where you are watching a series of still photos, where the entire photo -- top to bottom, and left to right -- comes from the same instant in time.
	I'm confused about the scan lines mostly displacing each other. Wouldn't that make objects appear to expand and contract, since things would be out of alignment? Or is it that the low pass filter would make it so that the smallest detail in the vertical dimension was two scan lines, so every other scan line would basically be a duplicate of the one before it? I thought I read that the filter only reduced resolution by 30%, though.
  Fixing aliasing/combing in PAL progressive helpBy spiritgumm in forum RestorationReplies: 10Last Post: 27th Nov 2016, 13:29
  If video is progressive do I need to de-interlace before upscaling?By VideoFanatic in forum RestorationReplies: 5Last Post: 13th Sep 2016, 11:34
  Artifacts In Progressive SD Animation SourceBy LouieChuckyMerry in forum DVD RippingReplies: 48Last Post: 13th May 2016, 22:27
  Samsung TV 1080 50i h.264 file playback => interlaced combing issueBy raffie in forum DVB / IPTVReplies: 2Last Post: 29th May 2015, 05:29
  Combing on Progressive Footage?By hizzy7 in forum RestorationReplies: 2Last Post: 7th Apr 2014, 03:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
