  1. The audio for a particular film transfer I'm working on has these puttering in the audio for lack of a better word. It's on the film print. I've heard this in many transfers I've worked with over the years. What tool would be the best to remove it or at least mask it?
    You can hear it here: (file is very small, under 5MB)
    https://www.mediafire.com/?7yo51oxs10148c5
    Thanks!
    USA
    You could try the freeware audio editor Audacity. The Noise Reduction filter may help.
  3. Plenty of click's and pop's + hiss - you need audio editor capable to filter this - Adobe Audition seem to be more than OK but it is not free - you can give a chance to free Audacity http://manual.audacityteam.org/man/tutorial_click_and_pop_removal_techniques.html
