Hello All -
I am currently using Adobe Premiere to make my videos for VHS tapes. I want to provide my clients with DVDs of the same content.
What do I need to make these DVDs?
What model of writer do you suggest?
The DVDs dont need to be interactive at all, just to play in home and auto dvd players.
I noticed that the blank media for these DVD writers are kind of expensive, does any of these DVD writers write to regular blank CDs?
Any help is appreciated.
T1![]()
Make sure your footage is 720x480 frameserve to tmpgenc(check the convert section of the site) use the standard dvd template to start out with
i'd recommend pioneers' ao4 but check the dvd writers section of the site
most dvd burner come with mydvd or some such dvd authoring software.
most of them can but most dvd player don't accept minidvds(dvd's burned on cdr (by the way you can only put about 20mins worth on a cdr)) you might consider vcd instead if you don't want to fork the money for the media(if you don't know what vcds are, check out the what is section of the site)
hope that helps
Another DVD Speed Newbie Questions
By bobelk99 in forum Newbie / General discussionsReplies: 3Last Post: 16th Jun 2011, 00:25 -
Newbie Questions DVD to ????
By swezey in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2008, 09:19 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 13:08 -
Ultimate newbie questions concerning DVD saving and editing
By quickpick in forum Newbie / General discussionsReplies: 7Last Post: 31st Dec 2007, 15:59 -
This Newbie has a whole lotta questions about DVD burning
By HartsVideo in forum Newbie / General discussionsReplies: 49Last Post: 14th Jul 2007, 00:04
