I've just bought a tall four-drawer steel metal filing cabinet for storing my media in. But the thought just occurred to me - is it actually safe for storing tapes in? Would there be any issue with the metal structure affecting what's on the tapes? Sorry if this sounds like a daft question to some of you here but I just want to be sure!
Thanks,
Gil
Dust, temperature and humidity should also be controlled for longevity of the tapes.
Static electricity or magnets wouldn’t be good for tapes, I suppose. -
It shouldn't - in fact it may even help and work as crude Zero Gauss Chamber - however it depend from many factors like material characteristic for cabinet - best it should soft magnetic characteristic with high permeability - some special alloys are best but even regular steel should be ok for some time.
The tape will fall apart long before the Earth's magnetic field has an appreciable effect. Tape reels and cassettes should be stored vertically, not lying down.
Best way to capture Hi8/8mm tapes
By Sir_Loin in forum Capturing and VCRReplies: 4Last Post: 17th Mar 2016, 04:35 -
Can Hi8 distorted tapes recorded on 8mm camcorder, play on Hi8 camcorder?
By RebeccaJB in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2014, 17:39 -
Help! HI8 to Mac transfer through Mini DV
By sketchypremise in forum Capturing and VCRReplies: 5Last Post: 20th May 2014, 11:18 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 19:53 -
Capturing video from Hi8 tapes
By Thanasis in forum Capturing and VCRReplies: 3Last Post: 1st May 2012, 00:21
