Is there a better or more recommended way to scale the picture on a DVD of mine into a higher resolution that actually looks fairly nice?
I suppose I could use avisynth and lanczos or spline resizers, but there's probably a much better way to keep the picture from blurring and scaling it better.
Does anyone have any suggestions that would provide better results than just resizing in avisynth?
Results 1 to 16 of 16
That waifu2x looks like it's for still pictures/images, not video scaling and editing.
The nnedi3 I will have to check out. -
- My sister Ann's brother
With animated material you can upscale and get very sharp results without aliasing or bad oversharpening halos. Much better than the upscaling any player or TV can do.
There is a waifu2x filter for AviSynth but it's dreadfully slow. Use nnedi3_rpow2(), aWarpsharp(), and Sharpen(). -
Yes, done carefully you can make the upscale look better than the SD original. But upscaling by itself won't make those improvements. It takes more work than just enlarging the frame. The OP thinks he'll get "high resolution" from the source. It won't happen.
- My sister Ann's brother -
Thanks, I will give them both a try when I return home.
I didn't expect it to become HD quality, I was just hoping to find a way to get clearer looking scaling results than the only method I could think of. Even if it ends up somewhat better/clearer looking on my TV/Computer that would be nice. -
I usually use a sequence like:
Code:#starting with an SD frame, after noise reduction, decimation, etc. nnedi3_rpow2(2, cshift="Spline64Resize", fwidth=960, fheight=720) aWarpSharp2(depth=5) Sharpen(0.2) nnedi3_rpow2(2, cshift="Spline64Resize", fwidth=1440, fheight=1080) aWarpSharp2(depth=5) Sharpen(0.5)
This worked decent enough.
nnedi3_rpow2(2, cshift="LanczosResize", fwidth=1440, fheight=1080)
awarpsharp(depth=3, blurlevel=1)
LimitedSharpenFaster(ss_x=1.0, ss_y=1.00, strength=5, overshoot=0, undershoot=0, soft=0, edgemode=0)
Thanks Jagabo! -
If you can afford the CPU time I would recommend you use nnedi3_rpow2(4... so that you're downsizing with Lanczos rather than upsizing.
I don't mind the slower times and I have very good computer so I will give that a try.
Thanks! -
Nope - waifu2x is perfectly fine for video - like most of common resizers waifu2x doesn't use information form other frames to reconstruct higher spatial resolution (supersampling) - waifu2x is simply slow but if you have plenty of time and you searching for best results then waifu2x may be worth at least to try.
The vapoursynth waifu2x version is 30-40x faster than the avisynth version. The avisynth version has no CPU or GPU optimizations
Down-scaling help
By ChibiSqueeze in forum Video ConversionReplies: 8Last Post: 1st Jul 2016, 08:45 -
Help up-scaling anime
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2015, 01:30 -
PotPlayer subtitle scaling
By Hahahhaha in forum Software PlayingReplies: 10Last Post: 15th May 2014, 10:16 -
scaling question
By hoodleehoo in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2013, 06:29 -
KMPlayer and bicubic scaling
By Asterra in forum Newbie / General discussionsReplies: 1Last Post: 19th Feb 2012, 04:10
