Results 1 to 12 of 12
  1. hi...i can't find a program to work in my ubuntu 16.04 to encode 2 different video file in 1 (mp4 for the final) but i need to be encoded because the video is different and is not working with fast encode i try all this and the final video is black..
    (in my local pc i have idoo Video Editor Pro 3.5.0 and is working but for ubuntu i don't find nothing like this :/ )
    pls help
  2. Originally Posted by sneaker View Post
    i try this but is not working
    ffmpeg -i /root/a.mp4 -i /root/b.mp4 \
      -filter_complex '[0:0] [0:0] [1:0] [1:0] concat=n=2:v=1:a=1 [v] [a]' \
      -map '[v]' -map '[a]' /root/output.mp4
    is wrong the code??
  3. and replacing
    -filter_complex '[0:0] [0:0] [1:0] [1:0] ...
    with
    -filter_complex '[0:v:0] [0:a:0] [1:v:0] [1:a:0] ...
  4. or create a mylist.txt
    # this is a comment
    file '/root/a.mp4'
    file '/root/b.mp4'
    ffmpeg -f concat -safe 0 -i mylist.txt output
  5. [Parsed_concat_0 @ 0xc981a0] Input link in1:v0 parameters (size 1280x720, SAR 1: 1) do not match the corresponding output link in0:v0 parameters (1920x1080, SAR 1:1)
    [Parsed_concat_0 @ 0xc981a0] Failed to configure output pad on Parsed_concat_0
    Error configuring complex filters.
    Invalid argument
  6. Oh your videos file have not the same resolution.
    and something like :
    ffmpeg -i /root/a.mp4 -s 1280x720 -i /root/b.mp4 \
    -filter_complex '[0:v:0] [0:a:0] [1:v:0] [1:a:0] concat=n=2:v=1:a=1 [v] [a]' \
  7. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    Install Kdenlive. Set project properties to 1280x720. Import both clips into timeline. Export render.
  8. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    You are trying to make an Orpple(joining and apple and an orange).....not gonna happen easily.
  9. Originally Posted by racer-x View Post
    i have this program in my server but is not open is not running
  10. Member racer-x's Avatar
    Mar 2003
    You'll need to install kde-runtime if you're running a desktop other than KDE. Kdenlive is a KDE application. Or download and run the Kdenlive AppImage. That should work on all desktops. https://kdenlive.org/download/
  11. i have the kdenlive and the runtime+appimage all but is not show up i don't know why (ubuntu os but i login from windows10+ xrdp interface)
