DNxHD is more of a intermediary format good for editing as every frame is in effect an I-frame, so every frame can be decoded by itself. It uses very similar compression as standard JPEG, MJPEG, and DV. Unlike formats like MPEG2, H.264, H.265, VP9 and so on which are more efficient compression oriented by supporting GOPs, which reduce duplicate image data across 10s-100s of frames. I would suspect that even the PP H.264 encoder would be more efficient than DNxHD, even if the PP H.264 encoder is not as efficient as x264.
Lossless compression would be the best way but if you are going lossy, then there more efficient options out there. Especially if this is just normal 8-bit 4:2:0 YUV stuff, which I'm assuming.
Results 31 to 31 of 31
You have a DV format video what do you do for editing and archiving?
By newpball in forum EditingReplies: 3Last Post: 13th Jul 2015, 05:27 -
Best file format for archiving
By lbeck in forum Video ConversionReplies: 6Last Post: 9th May 2014, 21:34 -
I need Help - Archiving old VHS tapes to Digital Format
By video80 in forum Capturing and VCRReplies: 27Last Post: 27th Mar 2014, 22:54 -
best archiving format
By shredhead in forum Video ConversionReplies: 3Last Post: 4th Nov 2012, 00:20 -
Archiving old Video 8 videos as MP4 question
By ShaneJensen in forum Video ConversionReplies: 7Last Post: 25th Jan 2012, 05:40
