I am searching for a free tool to exchange the audio track in video files (of type wmv) without re-rendering.
I am using "Windows Live Movie Maker" to compose my videos but I want to make the audio louder. I found a tool "Audacity" that can read the audio track, so I'm able to normalize the audio level. But now I need to exchange the audio track in the wmv file with the new sound file. I could use "Windows Live Movie Maker" again, but it's cumbersome and it takes time.
So is there a free tool that allows me to simply exchange the audio track in my .wmv file?
I'm using windows 7 as operating system.
Thanks a lot in advance. Bye,
Michael
Results 1 to 11 of 11
I used to do that, there was an tool for that, not sure exactly it was a tool that had a word "editor" or "stream editor" in it, it might come with Windows Media Encoder.
Thank you for the suggestion; I will have a look at them.
Bye,
Michael -
Windows Media Encoder 9, perhaps? https://www.videohelp.com/software/Windows-Media-Encoder
There is also https://www.videohelp.com/software/WMVMuxer
Not used WMV for years. Good luck.Last edited by transporterfan; 24th Jan 2017 at 18:50.
Marsia MarinerGuest
AsfBin.
Or ffmpeg, if you're not afraid of the command-line interface.
The Windows Media Encoder tools MAY be a trouble on Windows 7 x64 and later, so I cannot recommend them.
I don't recommend WMVmuxer either, it's buggy as hell and hasn't been updated or fixed. -
OK, thank you. I tried ffmpeg.exe version 3.2.2 with the following commands:
ffmpeg -i test.wmv -vcodec copy -an test_silent.wmv
ffmpeg -i test_silent.wmv -i test_louder.wav -vcodec copy -c:a copy test_louder.wmv
to first create a silent video and then put the new audio. It works but it seems to change the video.
Output of ffmpeg below. The properties of the original video are 8000 kBits/s and 25fps; the new has 1538 kBits/s and 15fps. Any ideas?
Thank you.
ffmpeg version 3.2.2 Copyright (c) 2000-2016 the FFmpeg developers
built with gcc 5.4.0 (GCC)
configuration: --enable-gpl --enable-version3 --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
libavutil 55. 34.100 / 55. 34.100
libavcodec 57. 64.101 / 57. 64.101
libavformat 57. 56.100 / 57. 56.100
libavdevice 57. 1.100 / 57. 1.100
libavfilter 6. 65.100 / 6. 65.100
libswscale 4. 2.100 / 4. 2.100
libswresample 2. 3.100 / 2. 3.100
libpostproc 54. 1.100 / 54. 1.100
[wmv3 @ 000000000055d340] Extra data: 8 bits left, value: 0
Input #0, asf, from 'two.wmv':
Metadata:
WMFSDKNeeded : 0.0.0.0000
DeviceConformanceTemplate: M1
WMFSDKVersion : 12.0.7601.17514
IsVBR : 0
Duration: 00:00:02.23, start: 0.000000, bitrate: 9850 kb/s
Stream #0:0: Video: mjpeg, yuvj420p(pc, bt470bg/unknown/unknown), 1920x1080, 90k tbr, 90k tbn, 90k tbc
Metadata:
comment : Movie/video screen capture
Stream #0:1: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080, 8000 kb/s, 25 fps, 25 tbr, 1k tbn, 1k tbc
Stream #0:2: Audio: wmapro (b[1][0][0] / 0x0162), 48000 Hz, stereo, fltp, 384 kb/s
Output #0, asf, to 'two_silent.wmv':
Metadata:
IsVBR : 0
WM/EncodingSettings: Lavf57.56.100
Stream #0:0: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080, q=2-31, 8000 kb/s, 25 fps, 25 tbr, 1k tbn, 1k tbc
Stream mapping:
Stream #0:1 -> #0:0 (copy)
Press [q] to stop, [?] for help
frame= 55 fps=0.0 q=-1.0 Lsize= 2338kB time=00:00:02.16 bitrate=8864.2kbits/s speed=15.3x
video:2317kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.940209%
H:\louder\ffmpeg-3.2.2-win64-static\bin>ffmpeg -i two_silent.wmv -i two_louder.wav -vcodec copy -c:a copy two_louder.wmv 1>loud.txt
[wmv3 @ 00000000004b2d60] Extra data: 8 bits left, value: 0
Input #0, asf, from 'two_silent.wmv':
Metadata:
IsVBR : 0
encoder : Lavf57.56.100
Duration: 00:00:02.20, start: 0.000000, bitrate: 8707 kb/s
Stream #0:0: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080, 25 fps, 25 tbr, 1k tbn, 1k tbc
Guessed Channel Layout for Input Stream #1.0 : stereo
Input #1, wav, from 'two_louder.wav':
Duration: 00:00:02.22, bitrate: 1536 kb/s
Stream #1:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s16, 1536 kb/s
Output #0, asf, to 'two_louder.wmv':
Metadata:
IsVBR : 0
Stream #0:0: Video: wmv3 (Main) (WMV3 / 0x33564D57), yuv420p, 1920x1080, q=2-31, 25 fps, 25 tbr, 1k tbn, 1k tbc
Stream #0:1: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, 1536 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (copy)
Stream #1:0 -> #0:1 (copy)
frame= 55 fps=0.0 q=-1.0 Lsize= 2948kB time=00:00:02.19 bitrate=10991.6kbits/s speed=16.8x
video:2317kB audio:416kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 7.878625%
Marsia MarinerGuest
Compare the combined filesize of the input streams with the expected filesize of the resulting output.
If there are no huge differences, then the error is not in ffmpeg, but in the user themselves.
Also, just to be on the safe side, you should examine "test_louder.wmv" with MediaInfo.
AFAIK, ffmpeg does NOT include a WMV3 or VC-1 encoder, therefore it's highly-improbable that it can do anything with these video formats except remuxing them (OR re-encoding them to a different format).Last edited by Marsia Mariner; 13th Feb 2017 at 23:41. Reason: disambiguation
Thank you for the answer and sorry for the late reply. I checked the files with Media Info and here are the differences under the VIDEO section (original versus processed):
Format profile
"MP@HL" versus "Main"
Description of the codec
"Windows Media Video 9 - Professional" versus "wmv3"
Bit rate
Constant "8 000 kb/s" versus "8 318 kb/s"
Bits/(Pixel*Frame)
"0.154" versus "0.160"
Stream size
"530 MiB (96%)" versus "551 MiB (81%)"
The rest under VIDEO is all the same. Attached the full info as text file. Does this now mean that the video stream was touched by ffmpeg.
Can't seem to get Windows movie maker to play wmv file.
By Al Bixby in forum Newbie / General discussionsReplies: 1Last Post: 19th Aug 2015, 18:15 -
Swap audio track on a WMV without recompressing it?
By daninthemix in forum AudioReplies: 6Last Post: 29th Apr 2013, 17:11 -
To exchange the audio in a mp4 container
By brusno in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2013, 16:17 -
How to add second audio track into a MKV file?
By WJohn in forum Newbie / General discussionsReplies: 7Last Post: 12th Oct 2012, 07:14 -
Adding a second audio track to the exiting DVD movie
By benwong in forum Authoring (DVD)Replies: 13Last Post: 11th Sep 2012, 03:32
