I'm looking for an app that can create video dvds with maximum 10mb bitrate and supports the 1600kbps audio bitrate (i think is only LPCM). Also a good video converter
with the same abilities.
	Also i want the apps to have the ability to stretch at full screen in either 4:3 and 16:9 aspect ratio.
	avstodvd will allow you to set the bitrate for encoding video to the maximum dvd spec of 9.8. But why you should want to go that high begs the question since even commercial disks usually peak at 6.
 You would need a high quality source since throwing more bitrate at low-quality source is not going to make it better.
 Same with audio. If you have a PCM source then the same program will use it. But you gain nothing by converting a lossy source to uncompressed.
 As to your Q. about stretching 4:3 video to full screen then as John Macnroe would say "You can not be serious"
	You had better read What Is DVD where you'll read that "Total bitrate including video, audio and subs can be max 10.08 Mbit/s (10080 Kbit/s)"
 So, with an LPCM audio track, your max video bitrate will be much much less than you're asking. All decent encoding and authoring programs can create DVDs making full use of the DVD specs.
	I mean i want a program to convert 4:3 to 16:9 aspect ratio without leaving me black borders at the sides of the screen when i play it at 16:9 aspect ratio tv. Most programs do this
 and have black borders on 16:9 aspect ratio videos at all 4 sides when played at 16:9 aspect ratio widescreen tv without the options to turn it at full screen or crop. And i need this
 program to have option to select 1600kbps audio (LPCM or other).
	4:3 video displayed on a 16:9 tv with side borders is the correct way. To have that shown without the borders then you would have to crop lines from top and bottom so you lose detail from the video.
 Borders on all sides could be from various reasons and again you would have to physically crop lines. There is no magic program to remove these.
 PCM audio is 1536 kbps. There is no such thing as 1600 kbps audio.
	https://www.videohelp.com/software/TMPGEnc-Authoring-Works
 Does it all. Not free though.
 By 'does it all' I mean will author to the max attributes of the dvd standard.
  Good quality DVD cases?By wubikens in forum MediaReplies: 6Last Post: 8th Feb 2015, 13:42
  Convert dvd to MKV with good quality - Handbrake settingsBy Spy_br in forum DVD RippingReplies: 1Last Post: 17th Jul 2014, 18:22
  Where to buy high quality DVD-R DL disks at a good price?By pawn3d in forum MediaReplies: 2Last Post: 4th Nov 2012, 16:03
  a good DVD Creator (with Menu) ?By ashe09 in forum Authoring (DVD)Replies: 1Last Post: 28th Jun 2012, 09:42
  Covert AVCHD to good quality DVD in premiere, how to?By Kentho in forum Video ConversionReplies: 14Last Post: 21st May 2012, 11:10
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
