i have used a a 730 mb divx about an hour and 45 mins. and converted it to vcd but i got the mpg thru virtual dub and used nero to make a vcd the picture quality is good but looks slight ly degraded as it is at the moment they fit with breathing room on 2 disks. how can i make the picture better?????
by the way the original divx was very high quality
whats up razz
what I did to make the picture look alot better
is I started using the filter "sharpen edge" in the tmpenc advanced settings
and it makes a great difference
it looks alot clearer
just pull both tabs all the way to the right
and make sure that enable filter is check
and the other box is NOT checked
another great thing about it is it does not increase encode time bu much if any
Y2Flyy
Improving Old Footage?
By PHNeedsHelp in forum EditingReplies: 1Last Post: 1st Jan 2012, 10:50 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Improving quality?
By BwanaP in forum Video ConversionReplies: 30Last Post: 19th Jan 2010, 22:03 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 07:41 -
Improving Hi8 Look
By rvalich in forum Newbie / General discussionsReplies: 0Last Post: 9th May 2007, 17:43
