This is one of the gross examples of the craziest things I do.
(Laugh all you like, I am for total freedom of expression)
Some of my videos play with correct dimensions on computer but stretch beyond the TV screen.
Going by all the knowledge gained in this forum, I think it has to do with Anamorphic setting to 'none' while re-coding.
Is it possible to restore these videos without loss in quality?
Thanks.
I suggest you do the following.
1. Post a mediainfo (text mode) report of one of these videos
2. Advise of the player(s) you use for the computer and any aspect ratio settings
3. Advise of the player(s) you use for the tv and any aspect ratio settings
4. Advise of the dimensions of your tv ie 4:3 or 16:9 and any display settings. Make model will also be useful. -
Thanks for reply.
1. Mediainfo:
2. Potplayer: Default display A/RPHP Code:General
Complete name : D:\Videos\Nature_Creative n Interesting\WaveBubbles at BEST.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/avc1/mp42)
File size : 16.1 MiB
Duration : 1 min 4 s
Overall bit rate : 2 103 kb/s
Encoded date : UTC 2009-06-30 05:43:22
Tagged date : UTC 2012-07-14 18:25:16
gsst : 0
gstd : 64620
gssd : BD075FCC8HH
replaygain_track_gain : -0.37
replaygain_track_peak : 0.49
replaygain_track_minmax : 102,178
replaygain_undo : -2,-2
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Bit rate : 1 990 kb/s
Maximum bit rate : 3 751 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.086
Stream size : 15.2 MiB (95%)
Title : (C) 2007 Google Inc. v08.13.2007.
Tagged date : UTC 2009-06-30 05:43:23
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Bit rate mode : Variable
Bit rate : 111 kb/s
Maximum bit rate : 147 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Stream size : 878 KiB (5%)
3. Samsung: built-in MediaPlayer
4. Samsung: 16:9
The setting doesn't hold good and changes the moment I select built-in MediaPlayer.jagabo
Turn off the overscan setting on the TV. -
Look also at tv display settings. My Sony has 'Auto', 'Wide', 'Smart' and 'Zoom'.
'Smart' is not very clever and zooms the displayed image. -
VSDC Split-Screen and merge videos
By SimBeam in forum EditingReplies: 3Last Post: 18th May 2015, 17:22 -
Capturing Screen Shot From Videos
By montevo in forum Newbie / General discussionsReplies: 2Last Post: 22nd Dec 2012, 09:38 -
HELP! Taking HD videos from the iPad's screen to SD DVD
By aliagha77 in forum Authoring (DVD)Replies: 38Last Post: 9th Aug 2012, 14:40 -
Videos from screen capture software
By snafubaby in forum Video ConversionReplies: 1Last Post: 18th Mar 2012, 04:35 -
Green screen in WMP and browser videos
By kerbone in forum Software PlayingReplies: 6Last Post: 27th Feb 2012, 02:28
