Hey all, I'm trying to recreate an audio effect using Sony Vegas but I'm having trouble identifying what it is. It's some sort of reverb effect but I can't seem to figure out just how to recreate it. Possibly reverb mixed with delay? I don't know... Could anyone help at all? I've attached a snippet of the audio effect in question (it's from Dragon Ball Z Kai, btw) and any help identifying it would be greatly appreciated (also, if this isn't the place to ask this sort of thing, please let me know). I'm using Sony Vegas Pro 13, but I'm open to using outside programs if I have to.
As you say, it's a mixture of delay (echo) and reverb. I don't use Vegas so I can't suggest anything there... but it's simple enough to do in Audacity, the free audio editor.
Simply import your clip and then select 'Delay' and 'Reverb' from the drop down 'Effect' menu. All the parameters are adjustable, so you can 'tweak' the settings - and then preview - to get to what you need.
You could try both ways round, but I suspect using delay first will probably get you closer to your sample clip.... -
download nastydla and epicverb here...
https://varietyofsound.wordpress.com/downloads/
these plugins should work on vegas. -
Identifying the file format of recorded TV
By npat in forum Newbie / General discussionsReplies: 6Last Post: 12th Jul 2016, 11:02 -
What's this audio effect called?
By langf in forum AudioReplies: 1Last Post: 30th Apr 2015, 15:52 -
Need help identifying analog artifact
By helmutik in forum Capturing and VCRReplies: 11Last Post: 31st Jul 2013, 08:51 -
Help Identifying Source
By Charolastra in forum DVD RippingReplies: 8Last Post: 14th Apr 2012, 03:19 -
Can you please help identifying this file ?
By fa355115 in forum Video ConversionReplies: 1Last Post: 23rd Jan 2012, 08:27
