Hello,
I suddenly discovered something I had been looking for -- for a long time -- to save extra features on a DVD.
While exploring a movie DVD in PgcEdit, I found a 'video' (most likely a slideshow with music playing in background).
The PGC panels shows it as:
VTSM 4, LU1 (en), 10 (2:03) 4b.
Must say, I don't understand this PgcEdit stuff.
Now, the big question – how to save it as a video or slideshow with music?
Will be thankful for suggestions.
Results 1 to 16 of 16
See if the DVD opens with DVDDecrypter first....MUCH easier than PgcEdit.
Thanks for the reply.
It doesn't work on ripped to hard disk DVD folders.
Is there a workaround? -
pgcdemux if you want to make your own stuff later (reauthor), or for a canned package I second DVDShrink, but if you run DVDShrink in reauthor mode, you should run PGCEdit on it afterwards before burning. PGCEdit will find an error DVDShrink makes when using reauthor mode.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Reauthor.
Drag it over to the left pane.
Output as DVD. It will probably be one, small VOB file.....almost as good as a straight MPG2 file. -
@hech54
Thanks a ton!
Done.
Never felt so happy.Last edited by ConverterCrazy; 17th Jan 2017 at 14:29. Reason: spelling
It's necessary only if you make a compilation of many (small) titles on a single DVD with DVDShrink. In that case, DVDShrink has a huge bug and the DVD cannot work correctly. For a single title, it should have no problem.
r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV -
I've had it come up with single titles before. In any case, I always have pgcedit check it. It only takes a second, so why not if you are going to through the effort to do all this anyway?
I've found a real PgcEdit fan! Thanks, Ron!
Thanks.
I find PgcEdit too intimidating. So, I followed @hech54's suggestion. And 'Re-authored' the DVD with all images but I was unable to add any audio track for background music.
Playing the 'new' DVD wasn't fun, every picture just flashed and was gone in seconds!
Then, using MKVMerge, I appended** all images (that were in VOB format), but, MKVMerge won't budge ('No Video detected').
So, I added a favorite music AC3 as audio track, the MKVMerge came into action. But, the images didn't appear slow enough to read the text therein. To correct that I set FPS value to 1/5 in Format specific options for video track and clicked 'Start muxing'.
All went fine and I got what I wanted.
Note: Everything I did above I learned in this Forum.
I have posted what I did and not how-to-do-it kind of thing. I don't even know if this is the right way!
Thank you all.
** Clarification: I selected the first VOB with image, MKVMerge selected all VOBs on its own. I did not use 'Append' button.Last edited by ConverterCrazy; 27th Jan 2017 at 09:51. Reason: Clarification
part progressive, part interlaced - correct avisynth coding question
By pooksahib in forum Video ConversionReplies: 14Last Post: 15th Dec 2016, 14:21 -
The eternal problem of saving videos from YouTube...
By Elhombresombra in forum Video Streaming DownloadingReplies: 34Last Post: 2nd Apr 2016, 07:49 -
How to convert *.mkv to *.avi with copy video part and re-encode audio part
By pxstein in forum Video ConversionReplies: 13Last Post: 1st Aug 2014, 11:24 -
need some help down loading and saving videos from a site
By hendrix in forum Video Streaming DownloadingReplies: 1Last Post: 21st Mar 2014, 10:34 -
Saving on line videos
By Videographer in forum Video Streaming DownloadingReplies: 5Last Post: 9th Aug 2012, 17:04
