I'm looking for a non-linear editor that can "smart render" DVD-compliant files - both video (MPEG-2) and audio (AC3). To give you some background, my workflow is simply VHS -> DVD recorder. From there, I'm ripping the DVD to my Windows 7 (64-bit) PC, and would like to achieve the following:
And after all that, the goal is to output a file with exactly the same specs as the sources, all ready for authoring to DVD in a separate program. As each clip will be 99% untouched, for the sake of not losing quality unnecessarily, I'd like to take advantage of "smart rendering". I stress that this goes for both video and audio.
- Basic cutting and joining
- Fades in and out (video and audio)
- The occasional transition
- Maybe some titles and captions here and there
- Whatever little fixes are necessary
I appreciate that asking for an NLE for all of that may come across like using the proverbial sledgehammer to crack a walnut, and if it can't be done, I'll soldier on with the various workarounds I'm currently using. But I don't think I'm asking the impossible... Am I?
Maybe some tmpgenc product. They support smart rendering. Tmpgenc mpeg2 smart renderer or Tmpgenc authoring works.
Sony MovieStudio and Vegas PRO also supports mpeg2 smart rendering. -
Maybe some tmpgenc product. They support smart rendering. Tmpgenc mpeg2 smart renderer or Tmpgenc authoring works.Videoredo doesn't do fades nor transitions, hwoever manages edits just fine and their support is great.
Also check out Womble Video Wizard DVD or MPEG-VCR.
Does no one use Nero's video editing tool? -
I own Vegas, and it can do smart rendering of MPEG-2 content, but it is very finicky, and it fails as often as it succeeds.
I need to smart render all sorts of different video formats, so I came up with a way that lets me use Vegas to do all the cuts and rearranging, and then do all the actual cuts with ffmpeg. You don't need to know anything about ffmpeg syntax to make it work.
What I do is the save the Vegas project (this will work with Movie Studio as well) as an EDL (Edit Decision List). I then import this into an Excel spreadsheet which contains a macro I wrote which converts the EDL into ffmpeg syntax. I copy/paste the results into a batch file, and when I execute that batch file, it runs ffmpeg to actually do the cuts. Here's a link to that Excel file:
Vegas EDL Cut Video Files Parser.xls
Another idea: if you search for the name "Nick Hope", you'll find that he created another workflow that does a similar thing.
Finally, here's a third alternative that uses Vegas (or Movie Studio) to do the editing, but then uses Womble to actually do the smart rendering. This workflow is actually a little simpler, but it does involve owning Womble (a paid program) as well as some version of Vegas. You make your cuts in Vegas (or Movie Studio), save as an EDL, and then use the free EDL to Womble converter. You then do the cuts in Womble. Here is a link to that free converter:
Vegas To Womble Converter
H265 - Any tool to make a "smart rendered" cut?
By Seeker320 in forum EditingReplies: 2Last Post: 4th Oct 2015, 20:48 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 07:21 -
[Help] Problems with the "Title Button" in the "VTS ROOT" and "VTS Normal"
By kirous in forum Authoring (DVD)Replies: 8Last Post: 1st Nov 2014, 12:31 -
Best way to make a "dumb tv" smart?
By sdsumike619 in forum DVD & Blu-ray PlayersReplies: 22Last Post: 29th Nov 2013, 21:55 -
Process a MP4 (Quicktime) in a "smart rendering" way. Not to be re-encoded
By whenloverageswild in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Mar 2012, 09:53
