mplayer { -display xxx } does not work, says 'option unknown'
ffplay does not seem to be any methods so far, via good searches
I am currently dragging the videos files from an explorer window onto ffplay, and when it opens the video and plays I quickly move the mouse over to the far right edge of the window to click it, this is so that it changes the windows view style to 'movable' and then I can move the mouse over to the top caption bar and then drag it to the second AOC 1920x1080 monitor, press "F" key to fullscreen the video. The second monitor is connected to my 1366x768 laptop via HDMI. This is how i've been doing it all this time but it is becoming tedious and i'd like to just go straight over to the second monitor w/out all those extra steps.
fwiw, MPC-HC does not allow this, even when I drag its window to the second monitor and press Alt+Enter key, the video will play fullscreen but only on my laptop's screen.
Mplayer option "-screen <x>" should work; requires OpenGL, option "-vo gl"
http://www.mplayerhq.hu/DOCS/man/en/mplayer.1.txt
[SOLVED]Use ffplay to check how much to brighten video before using ffmpeg?
By yetanotherlogin in forum EditingReplies: 1Last Post: 16th Mar 2016, 05:59 -
Ffmpeg/Ffplay: simultaneous playback of two videos, or video+histogram?
By zopiro in forum EditingReplies: 4Last Post: 19th Dec 2015, 11:44 -
Video playback issues in MPC-HC with madVR but not DXVA on second monitor
By FrozenClear in forum Software PlayingReplies: 2Last Post: 28th Aug 2015, 10:56 -
x264+AAC in FFmpeg -- plays fine in FFplay, loses sync in mplayer
By rusmichal in forum Video ConversionReplies: 2Last Post: 6th Apr 2013, 08:52 -
Target Bitrate for post-processed DSLR video, playback on 2560x1440 monitor
By savvyguy in forum Newbie / General discussionsReplies: 6Last Post: 22nd Dec 2012, 10:36
