I saved a .vob into HuffYUV codec and then open it in avidemux, do some filtering and try to save it again in the HuffYUV codec, but avidemux seems to be messing with the colors and I don't know how to fix it.
Video I'm opening in avidemux: https://mega.nz/#!YJZhGCbD!l0ggR3AUrtZ4cFytw0HcPYGgVv0uR2jpoqaDWYjdWh0
Vide I'm saving/exporting from avidemux: https://mega.nz/#!FcIAHYoY!9p83421xDowDsP7DJbgeY3VtGk2_JUM_RMx5O7uObk0
Any idea how I could fix this problem?
Your 'source' is RGB32 (why?) and the exported version is YUY2. All by itself that will change the colors if not done properly.
You should also mention the kind of filtering you did in case that might account for part of it.Last edited by manono; 16th Jan 2017 at 22:54.
Neverming, I figured out a way to do it. Thanks for alerting me to the color space issue though as I didn't think about that and it let me to finding the solution
You're welcome. Since the DVD is YV12 and, most likely whatever final format you'll be encoding to is also YV12, it's probably in your best interests to keep it in YV12 all the way through, if at all possible.
avidemux video color changes
By yukukuhi in forum EditingReplies: 14Last Post: 27th Jun 2016, 19:02 -
MPC color issue
By mlmiller707 in forum Software PlayingReplies: 12Last Post: 28th Nov 2015, 13:43 -
Color issue in x265 encode
By Evad3R in forum Video ConversionReplies: 48Last Post: 6th Mar 2015, 14:25 -
how to fix a color issue on bright areas
By mathmax in forum RestorationReplies: 9Last Post: 19th Nov 2012, 16:29 -
AVIDemux avi issue.
By dariog in forum Newbie / General discussionsReplies: 8Last Post: 25th May 2012, 14:59
