Anyway. Just how large is this vob ? I thought you had already split at chapter level. The split vob could be uploaded here.
But all this would be un-necessary if you simply accepted, like 99.99% of forum readers, that a 720*480 dvd properly displays square 640*480.
Of vourse it is quite possible that you have not done the conversion correctly. Surely Vegas can export direct to H264 640*480 without any need to invole frame-serving and handbrake. But if you do insist then do check all the settings in handbrake as there are many which will be codec specific.
Results 31 to 39 of 39
Yes, 640x480 looks correct. The thing that was making it look wrong was that Anamorphic setting. I had to set that to none, and uncheck the keep aspect ratio.
Once I did those two things, the encoded video looks correct. When I had Anamorphic on Automatic setting, it was showing a PAR of 9x8 in Handbrake even though the frame size was 640x480. That was the issue. -
Yes, Vegas has a number of h264 options (AVC, AVCHD, XAVC are all h264). However, in my experience - especially if I'm starting with a DVD source - I get better results if I render the video in Vegas as a DVD-compliant MPEG2 video, and convert it to h264 using HandBrake (or VidCoder, which is just a different GUI using the HandBrake core). And I have seen comments in the Vegas community forum from other users who also share that opinion.
Do or do not. There is no "try." - Yoda -
Oh, I know that. I was responding to the suggestion that you could use Vegas to create your h264 files.
I was saying that if I'm starting with a DVD source and going to h264, and I'm doing any editing in Vegas, I will keep the Project Properties in Vegas to match the DVD files, and then render it back to an MPEG2 video. That retains as much of the original quality as possible. Then I'll use HandBrake to convert it to h264 (And from what I gather, that is exactly what you're doing). In my experience at least, HandBrake produces a better looking h264 result than if I try to render it as h264 directly in Vegas.Do or do not. There is no "try." - Yoda -
Yes sometimes Vegas exports without rendering (only fixing new GOP if broken while editing) , setting MainConcept mpeg2, same parameters and setting CBR and maximum bitrate (what mediainfo reports), it not always work, in op case, sample might be too short, lacking original GOP, I tested it and it did not work. Video seems to be truly interlaced, lower field first.
Finding individual "bad" frames in video and save frame number, or repair
By johnmeyer in forum RestorationReplies: 6Last Post: 13th Dec 2016, 21:59 -
Update: Creating individual chapters using Leawo program
By Marshfish in forum Authoring (Blu-ray)Replies: 2Last Post: 10th Aug 2015, 15:11 -
Leawo Blu-ray Creator-Making individual chapters
By Marshfish in forum Authoring (Blu-ray)Replies: 0Last Post: 2nd Aug 2015, 17:19 -
Does VOB2MPG Pro cut on a keyframe when selecting individual chapters?
By xero9009 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 23rd Sep 2014, 12:30 -
Tricky DVD to rip, individual chapters only
By indijay in forum DVD RippingReplies: 3Last Post: 12th Jan 2014, 19:37
