im trying to encode a file in staxrip and i read it would be for the best to enable lookahead for the best results but i have added the command and keeps failing
"keeps failing" is not a good error description. Post your settings, show error message/log. You didn't even say what encoder you are using.
i found the following on another site but when i copy and paste the command for activating lookahead i get an error, im sure im just doing it wrong ...
NVEnc v2.08 update by rigaya
Because finally NVENC SDK 7.0 has been published today, the implementation so that it can be used only part somehow in the rush job. So did not have time, please note that not be barely tested in the fullest only implementation.
Basically, should that become such Lookahead and AQ is available. The bottom line of the 10bit is there also implement the likely time-consuming...
And responding to NVENC SDK 7.0
Requires NVIDIA graphics driver 368.69 or later
- Added an option of additional features in SDK 7.0.
--vbr-quality <int> (NVEncC only)
It sets the target quality at the time of VBR mode use. (0-51, 0 = automatic)
--lookahead <int>
To enable the lookahead, to specify the target range by the number of frames. (0-32)
With help to improve the image quality, adaptive I, B frame insertion is enabled.
--no-i-apapt (NVEncC only)
lookahead to disable the adaptive I-frame insertion at the time of effectiveness.
--no-b-apapt (NVEncC only)
lookahead to disable the adaptive B-frames insertion at the time of effectiveness.
--strict-gop (NVEncC only)
To force a fixed GOP length.
--enable-ltr (NVEncC only)
LTR the (Long Term Reference pictures) to enable.
--aq
To enable the adaptive quantization of the frame (spatial direction). (Default: off)
--aq-temporal
To enable the adaptive quantization between the frame (time direction). (Default: off)
--aq-strength <int>
To specify the AQ strength. (1 (weak) to 15 (strong), 0 = automatic)]
StaxRip
By stax76 in forum Video ConversionReplies: 719Last Post: 12th Dec 2025, 12:23 -
x264 lookahead-threads vs quality and
By kotuwa in forum Video ConversionReplies: 2Last Post: 23rd Sep 2015, 13:57 -
Where is 'sharpen' in new Staxrip?
By The.King in forum Video ConversionReplies: 0Last Post: 2nd Sep 2015, 07:44 -
I need the filters of StaxRip...
By yaston in forum Video ConversionReplies: 3Last Post: 22nd Jan 2014, 12:54 -
How can you use the best filters of StaxRip
By yaston in forum Video ConversionReplies: 3Last Post: 13th Jan 2014, 11:41
