Results 1 to 12 of 12
  1. Hi, I'm new here in the forums , I came here because I'm having some problems trying to replace subtitles from a video.
    I want to remove the current ones that are in the file and put another subtitle instead using mkvmerge from the terminal. (I want to do it for a bunch of files using a batch script)
    So for remove the current subtitles I’m using this command:
    for i in *.mkv; do
      mkvmerge --no-subtitles "$i" -o WithoutSubs/"$i"
    done
    My problem is when I try to add the new subtitles I must duplicate my files again because mkvmerge always ask me for an output file instead of replace the current one.
    There is any way to remove the currents subs and add another one into a single output file?
  2. Code:
    for i in *.mkv; do
      mkvmerge -o "./WithoutSubs/$i" --no-subtitles "./$i" "./${i%.*}.ass"
    done
  3. Originally Posted by sneaker View Post
    for i in *.mkv; do
    done
    I got an error msg: "Could not open for reading: open file error."
    It's like I was trying to open the subs
  4. Post the complete error message/log. What is the file name of your subtitle file?
  5. Originally Posted by sneaker View Post
    mkvmerge v9.3.1 ('Mask Machine') 64bit
    Error: El archivo '*.ass' no se pudo abrir para su lectura: open file error.
    Sorry my system is in Spanish
    I run it changing the subs for *.ass so there is no problem with the name.
  6. Originally Posted by Akari View Post
    I run it changing chaing the subs for *.ass so there is no problem with the name.
    Mkvmerge doesn't support wildcards. Or do you mean you don't actually use the wildcard? I'm not sure I understand you correctly. If your shell interprets "./${i%.*}.ass" as "*.ass" then that's one more thing that's different on mine.
    Here I'd have:
    !#/bin/bash
    for i in *.mkv
    do
    done
    Maybe if you post your OS/shell someone else has advice on what you need to change.
  7. Yup, I'm running this:
    for i in *.mkv; do
      mkvmerge -o WithoutSubs/"$i" --no-subtitles "$i" "*.ass"
    done
    Because if I leave this as you instructed I got the same error that I got with the .ass subtitles. (the file './' could not open... open file error.)
    I'll try pass the exact subtitle file name now.
    Oh, I thought u could see it on my profile sorry.
    I'm running on Ubuntu 16.10 x64, bash 4.3.46
  8. And without "./"?
    !#/bin/bash
    for i in *.mkv
    do
      mkvmerge -o "WithoutSubs/$i" --no-subtitles "$i" "${i%.*}.ass"
    done
  9. Originally Posted by sneaker View Post
    And without "./"?
    !#/bin/bash
    for i in *.mkv
    do
    done
    It works! ty m8
  10. Srry for the double post.
    Do u know how can I pass the language code for the subtitle?
    I just try to add
    --language 0:spa
    but it doesn't work
  11. Tried to add where? What does "it doesn't work" mean? Error message?
    The command order is important.
    !#/bin/bash
    for i in *.mkv
    do
      mkvmerge -o "WithoutSubs/$i" --no-subtitles "$i" --language 0:spa "${i%.*}.ass"
    done
  12. Originally Posted by sneaker View Post
    !#/bin/bash
    for i in *.mkv
    do
    done
    I just come here to delete the msg xd
    For error I mean that I got the subs marked as undefined language but it just was a dumb mistake. I put that code after the subs
    Ty again
