For some reason, when I set MeGUI to Automated 2-pass, it only ever runs the first pass. I then have to go in, change it to 2pass - 2nd pass, and run it again.
Which is a pain, because it means I can't leave encodes to run overnight.
Any ideas why it's doing this?
Results 1 to 9 of 9
-[Information] Log for job5 (video, BluRay.avs -> ) --[Information] [14/01/2017 1:51:33 AM] Started handling job --[Information] [14/01/2017 1:51:33 AM] Preprocessing -[NoImage] AVISource("signpost.avi").AssumeFPS(25,1) -[NoImage] ColorMatrix(mode="rec.601->rec.709", interlaced=true) -[NoImage] ConvertToYV12(interlaced=true) --[Information] [14/01/2017 1:51:33 AM] Avisynth input script --[Information] [14/01/2017 1:51:33 AM] resolution: 1920x1080 --[Information] [14/01/2017 1:51:33 AM] frame rate: 25/1 --[Information] [14/01/2017 1:51:33 AM] aspect ratio: 16:9 (1.778) --[Information] [14/01/2017 1:51:33 AM] target device selected: Blu-ray --[Information] [14/01/2017 1:51:33 AM] changing --keyint to 25 as required for the selected device --[Information] [14/01/2017 1:51:33 AM] changing --ref to 4 --[Information] [14/01/2017 1:51:33 AM] Job command line: "[path]\avs4x264mod.exe" --level 4.1 --bluray-compat --preset slow --pass 1 --bitrate 28416 --stats "[path]\BluRay.stats" --keyint 25 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --qpfile "[path]\chapters.qpf" --tff --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --output NUL "[path]\BluRay.avs" --[Information] [14/01/2017 1:51:34 AM] Process started --[Information] [14/01/2017 1:51:34 AM] Standard output stream --[Information] [14/01/2017 1:51:34 AM] Standard error stream ---[Information] [14/01/2017 1:51:34 AM] --tff found. ---[Information] [14/01/2017 1:51:37 AM] raw [info]: 1920x1080i 1:1 @ 25/1 fps (cfr) ---[Warning] [14/01/2017 1:51:37 AM] x264 [warning]: interlace + weightp is not implemented ---[Information] [14/01/2017 1:51:37 AM] x264 [info]: using SAR=1/1 ---[Information] [14/01/2017 1:51:37 AM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 ---[Information] [14/01/2017 1:51:37 AM] x264 [info]: profile Main, level 4.1 ---[Error] [14/01/2017 1:51:37 AM] x264 [error]: can't parse qpfile for frame 0 ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: frame I:7024 Avg QP:15.01 size:460484 ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: frame P:46455 Avg QP:17.91 size:232888 ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: frame B:109913 Avg QP:20.61 size: 83302 ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: consecutive B-frames: 4.0% 13.8% 15.1% 67.1% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: mb I I16..4: 8.0% 0.0% 92.0% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: mb P I16..4: 26.8% 0.0% 0.0% P16..4: 70.4% 0.0% 0.0% 0.0% 0.0% skip: 2.8% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: mb B I16..4: 5.4% 0.0% 0.0% B16..8: 49.9% 0.0% 0.0% direct:22.5% skip:22.1% L0:25.5% L1:30.0% BI:44.4% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: field mbs: intra: 49.7% inter:43.8% skip:14.0% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: direct mvs spatial:100.0% temporal:0.0% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: coded y,uvDC,uvAC intra: 83.7% 86.5% 67.0% inter: 48.9% 36.7% 9.2% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: i16 v,h,dc,p: 18% 54% 21% 8% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 14% 41% 9% 5% 5% 4% 8% 4% 10% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: i8c dc,h,v,p: 36% 41% 14% 8% ---[Information] [14/01/2017 4:27:22 AM] x264 [info]: kb/s:28409.27 ---[Information] [14/01/2017 4:27:22 AM] encoded 163392 frames, 17.48 fps, 28409.27 kb/s ---[Information] [14/01/2017 4:27:25 AM] avs [info]: AviSynth 2.60, build:Mar 31 2015 [16:38:54] ---[Information] [14/01/2017 4:27:25 AM] avs [info]: Video colorspace: YV12 ---[Information] [14/01/2017 4:27:25 AM] avs [info]: Video resolution: 1920x1080 ---[Information] [14/01/2017 4:27:25 AM] avs [info]: Video framerate: 25/1 ---[Information] [14/01/2017 4:27:25 AM] avs [info]: Video framecount: 163392 ---[Information] [14/01/2017 4:27:25 AM] avs4x26x [info]: "x264_64" - --level 4.1 --bluray-compat --preset slow --pass 1 --bitrate 28416 --stats "[path]\BluRay.stats" --keyint 25 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --qpfile "[path]\chapters.qpf" --tff --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --output NUL --frames 163392 --fps 25/1 --input-res 1920x1080 --input-csp i420 --[Information] [14/01/2017 4:27:27 AM] Job completed -[Information] Log for job7 (video, BluRay.avs -> BluRay.264) -
The command line looks wrong to me.
The second pass command line appears broken. What version of MeGUI are you using? I think avs4x264mod.exe has been replaced with avs4x26x.exe, unless MeGUI uses different versions depending on the flavour of Windows.
Try switching to the development update server in MeGUI's options and running an update. The current version there is 2700. I have't problems with it. With any luck that'll fix the problem. If not, and you're not a member of doom9, post back and I'll report the bug in the MeGUI thread for you.
It's not very specific, but from the changelog, could this be the problem?
2688 [x264] fixed incorrect command line when using a x86 OS (regression of 2681)Last edited by hello_hello; 14th Jan 2017 at 09:58.
Just downloaded MeGUI 2624 a couple of days ago, was previously using 2525 and had the same issue. I'll give the update a shot.
I'm on an x64 OS.
EDIT: Now when I start MeGUI I get three errors about missing DLLs. VCOMP120, api-ms-win-crt-runtime-l1-1-0, and api-ms-win-crt-runtime-l1-1-0. The latter two appear to be the same thing.
Says the program can't start because they're missing, but then MeGUI opens anyway. -
Okay, I fixed that by running a repair installation of vc_redist. Tried a 2-pass encode with MeGUI 2700. Got exactly the same result.
Code:-[Information] Log for job8 (video, Menu17.avs -> ) --[Information] [15/01/2017 7:47:44 AM] Started handling job --[Information] [15/01/2017 7:47:44 AM] Preprocessing -[NoImage] AVISource("[path]\Intro.avi").AssumeFPS(25,1) -[NoImage] ConvertToYV12(interlaced=true) --[Information] [15/01/2017 7:47:44 AM] Avisynth input script --[Information] [15/01/2017 7:47:44 AM] resolution: 1920x1080 --[Information] [15/01/2017 7:47:44 AM] frame rate: 25/1 --[Information] [15/01/2017 7:47:44 AM] aspect ratio: 16:9 (1.778) --[Information] [15/01/2017 7:47:44 AM] target device selected: Blu-ray --[Information] [15/01/2017 7:47:44 AM] changing --keyint to 25 as required for the selected device --[Information] [15/01/2017 7:47:44 AM] changing --ref to 4 --[Information] [15/01/2017 7:47:44 AM] Job command line: "[path]\MeGUI_2624_x86\tools\x264\avs4x26x.exe" --x26x-binary "[path]\MeGUI_2624_x86\tools\x264\x264.exe" --level 4.1 --bluray-compat --preset slow --pass 1 --bitrate 12000 --stats "[path]\Menu17.stats" --keyint 25 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --me umh --trellis 1 --qpfile "[path]\MenuChapters.qpf" --tff --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --output NUL "[path]\Menu17.avs" --[Information] [15/01/2017 7:47:44 AM] Process started --[Information] [15/01/2017 7:47:44 AM] Standard output stream --[Information] [15/01/2017 7:47:44 AM] Standard error stream ---[Information] [15/01/2017 7:47:45 AM] --tff found. ---[Information] [15/01/2017 7:47:47 AM] raw [info]: 1920x1080i 1:1 @ 25/1 fps (cfr) ---[Warning] [15/01/2017 7:47:47 AM] x264 [warning]: interlace + weightp is not implemented ---[Information] [15/01/2017 7:47:47 AM] x264 [info]: using SAR=1/1 ---[Information] [15/01/2017 7:47:47 AM] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 AVX2 LZCNT BMI2 ---[Information] [15/01/2017 7:47:47 AM] x264 [info]: profile Main, level 4.1 ---[Error] [15/01/2017 7:47:47 AM] x264 [error]: can't parse qpfile for frame 0 ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: frame I:152 Avg QP: 9.39 size:601661 ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: frame P:833 Avg QP:16.41 size: 88974 ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: frame B:2474 Avg QP:22.75 size: 16846 ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: consecutive B-frames: 2.1% 3.9% 11.2% 82.8% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: mb I I16..4: 19.0% 0.0% 81.0% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: mb P I16..4: 6.9% 0.0% 0.0% P16..4: 13.6% 0.0% 0.0% 0.0% 0.0% skip:79.5% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: mb B I16..4: 0.2% 0.0% 0.0% B16..8: 7.3% 0.0% 0.0% direct: 1.2% skip:91.3% L0:40.2% L1:40.7% BI:19.0% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: final ratefactor: 15.00 ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: field mbs: intra: 4.6% inter:25.7% skip:0.2% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: direct mvs spatial:99.9% temporal:0.1% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: coded y,uvDC,uvAC intra: 76.4% 62.6% 52.2% inter: 4.6% 5.2% 4.5% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: i16 v,h,dc,p: 32% 44% 19% 5% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 30% 46% 9% 2% 2% 2% 3% 2% 4% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: i8c dc,h,v,p: 57% 26% 13% 5% ---[Information] [15/01/2017 7:49:18 AM] x264 [info]: kb/s:11982.97 ---[Information] [15/01/2017 7:49:18 AM] encoded 3459 frames, 37.30 fps, 11982.97 kb/s ---[Information] [15/01/2017 7:49:18 AM] avs [info]: AviSynth 2.60, build:Mar 31 2015 [16:38:54] ---[Information] [15/01/2017 7:49:18 AM] avs [info]: Video colorspace: YV12 ---[Information] [15/01/2017 7:49:18 AM] avs [info]: Video resolution: 1920x1080 ---[Information] [15/01/2017 7:49:18 AM] avs [info]: Video framerate: 25/1 ---[Information] [15/01/2017 7:49:18 AM] avs [info]: Video framecount: 3459 ---[Information] [15/01/2017 7:49:18 AM] avs4x26x [info]: "[path]\MeGUI_2624_x86\tools\x264\x264.exe" - --level 4.1 --bluray-compat --preset slow --pass 1 --bitrate 12000 --stats "[path]\Menu17.stats" --keyint 25 --open-gop --slices 4 --vbv-bufsize 30000 --vbv-maxrate 40000 --me umh --trellis 1 --qpfile "[path]\MenuChapters.qpf" --tff --colorprim bt709 --transfer bt709 --colormatrix bt709 --sar 1:1 --output NUL --frames 3459 --fps 25/1 --input-res 1920x1080 --input-csp i420 --[Information] [15/01/2017 7:49:18 AM] Job completed -
That's odd. I saw the error mentioned in the log file but assumed that was unrelated.
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
Megui 1 pass vs 2 pass for 480p->720p anime ,difference
By zanzar in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2016, 15:47 -
I found MEGUI X265 HEVC in MEGUI.ORG !!!!
By Stears555 in forum Video ConversionReplies: 11Last Post: 2nd Apr 2016, 15:00 -
Difference: 2nd pass of 2pass vs 2nd pass of 3pass!
By kotuwa in forum Video ConversionReplies: 16Last Post: 8th Jun 2015, 13:11 -
What's the difference between 2nd pass and two pass in h.264 encoders?
By Stears555 in forum Video ConversionReplies: 1Last Post: 26th Sep 2013, 06:09
