Hello there guys,
This is my first post in video help forums...Two players that I use is MPC-BE.1.5.1.2301.x64(nightly build) and Potplayer 1.6.63891..(config of both attached below)(both of them use default internal decoder)
Honestly speaking the only reason I installed mpc-be x64 was to play HEVC x265 videos with minimal cpu usage....I tested two files (mediainfo of both files attached) one 720p another 1080p...
For the 720p mpc-be showed highest 8% cpu usage whereas potplayer showed 18% cpu usage...
For the 1080p mpc-be showed 12- 18% cpu usage whereas potplayer showed 35-40% cpu usage...
My question is can the same be achieved in potplayer by tweaking some settings or using madvr/lav filters? Can i use the mpc-video decoder in potplayer? I tried disabling buit-in video processing settings in potplayer but didn't work...
Any advice from simple to advance would be really appreciated
Helpful "during playback info"
MPC BE(attached)
Potplayer(attached)
Those of you not feeling like opening the attachment heres full info anyways
mediainfo1
General
Unique ID : 253714678085939162673367598740941646071 (0xBEDFAB69F6B56238B0F0B58D77D928F7)
Complete name : C:\Users\test1\Downloads\The.Big.Bang.Theory.S10E1 1.720p.HDTV.x265.ShAaNiG.mkv
Format : Matroska
Format version : Version 2
File size : 106 MiB
Duration : 20 min 36 s
Overall bit rate : 716 kb/s
Encoded date : UTC 2016-12-17 03:17:54
Writing application : mkvmerge v7.8.0 ('River Man') 32bit built on Mar 27 2015 16:18:02
Writing library : libebml v1.3.1 + libmatroska v1.4.2
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L3.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 651 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.029
Stream size : 95.9 MiB (91%)
Writing library : x265 1.8+2-55a4a9b920ff:[Windows][GCC 5.2.0][64 bit] 8bit+10bit+12bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=0 / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=650 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Bit rate : 64.0 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz / 24.0 kHz
Frame rate : 23.438 FPS (1024 spf)
Compression mode : Lossy
Delay relative to video : 31 ms
Stream size : 9.43 MiB (9%)
Default : Yes
Forced : No
media info 2
General
Unique ID : 191361138015711959347631161984299666256 (0x8FF6D088F27916E0B88BEE182AD58B50)
Complete name : C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\Planet Earth 2006 (1080p x265 10bit Joy)\Planet Earth 01 From Pole to Pole (1080p x265 Joy).mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 648 MiB
Duration : 53 min 20 s
Overall bit rate : 1 699 kb/s
Encoded date : UTC 2015-09-11 22:41:39
Writing application : mkvmerge v7.9.0 ('Birds') 64bit
Attachments : exprswy_free.ttf / Framd.TTF
Video
Format : HEVC
Format profile : Main 10@L4@Main
Bit rate : 1 508 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Original frame rate : 23.976 (23976/1000) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.030
Stream size : 575 MiB (89%)
Writing library : x265 1.7+2-d7b100e51e82:[Windows][GCC 4.8.2][64 bit] 16bpp
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=20 / lookahead-slices=0 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / weightp / no-weightb / aq-mode=1 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.30 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / rc=2 / pass / bitrate=1508 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Audio
Format : AAC
Codec ID : A_AAC
Duration : 51 min 10 s
Bit rate : 197 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Stream size : 72.1 MiB (11%)
Language : English
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Duration : 49 min 23 s
Bit rate : 67 b/s
Count of elements : 366
Compression mode : Lossless
Stream size : 24.4 KiB (0%)
Language : English
Default : No
Forced : No
potplayer config
[AtscAntenaList]
0=
[AtscCableList]
0=
[DvbcList]
0=
[DvbsList]
0=
[DvbtList]
0=
[Positions]
1stCaptureY=257
2ndCaptureX=718
2ndCaptureY=257
AudioWindowRectB0=362
AudioWindowRectB1=508
AudioWindowRectB2=750
AudioWindowRectL0=202
AudioWindowRectL1=438
AudioWindowRectL2=869
AudioWindowRectR0=602
AudioWindowRectR1=698
AudioWindowRectR2=1176
AudioWindowRectT0=205
AudioWindowRectT1=100
AudioWindowRectT2=549
AudioWindowState1=0
AudioWindowState2=0
ControlBoxLeft=369
ControlBoxTop=530
MainHeight2=437
MainWidth2=650
MainX=37
MainY=99
TopMostWindow0=0
TopMostWindow1=0
TopMostWindow2=0
TopMostWindow3=0
TopMostWindow4=0
TopMostWindow5=0
TopMostWindow6=0
TopMostWindow7=0
TopMostWindow8=0
TopMostWindow9=0
VideoWindowHeight=360
VideoWindowWidth=640
[Settings]
AttachWindowIndex=2
AudioVolume=45
AutoDetectTimePL=1
AutoDownloadFile=0
BroadcastAttachToMain2=0
CaptionAutoLoad=1
CaptionRemoveEmpty=1
CaptionStyle=5;5;5;5;1;0;2.000000;2.000000;3.00000 0;3.000000;0xffffff;0x000000;0x000000;0x000000;0x0 0;0x00;0x00;0x90;1;Segoe UI;18.000000;100.000000;100.000000;0.000000;400;0; 0;0;0;0.000000;0.000000;0.000000;0.000000;2;1;1;50 ;95;0.000000;0
CaptionTrim=1
CaptionUseBitmapRas=1
ChatAttachToMain2=0
CheckAutoUpdate=0
ColorThemeIndex=2
D3DFullScreenUi=0
DropMousePos=1
EffectCastOnly=1
EffectPage=0
ForceCaptionLoad=1
IntDXVAUseMode=1
LastCheckDays=17083
LastConfigPage=377
LastPlayListName=PotPlayer.dpl
LastSkinXmlName=VideoSkin.xml
LastSkinXmlNameAudio=AudioSkin.xml
LastSkinXmlNameVideo=VideoSkin.xml
LogInfo=759749E0AC514F8BB61AF701B2D0663F
MediaKeyGlobal=1
MouseCaptionMove=1
MousePanScanControl=1
NoSameFileAddPL=1
OnTopMode=2
PauseOnMin=1
PlaybackMode=1
PlaylistAttachSize2=566
PlayScreenSize=10
RememberPosition=1
RepeatPlayAudio=1
RestoreLastState=1
SaveConfigPause=1
ShowRememberList=1
StartScreenSize=4
UseClipboardUrl=1
VideoSaturaction=65
mpc-be config
; MPC-BE
[Capture]
AudDispName=
AudOutput=1
AudPreview=1
Country=1
FileFormat=0
FileName=.avi
SepAudio=1
VidDispName=dummy
VidOutput=1
VidPreview=1
[Commands2]
CommandMod0=891 11 27 "" 5 0 0 0
CommandMod1=892 11 25 "" 5 0 0 0
CommandMod2=904 9 27 "" 5 0 0 0
CommandMod3=903 9 25 "" 5 0 0 0
CommandMod4=929 1 0 "" 5 0 0 0
CommandMod5=930 1 0 "" 5 0 0 0
CommandMod6=944 1 1b "" 5 0 0 0
[DVB configuration]
BDABandWidth=8
BDAIgnoreEncryptedChannels=0
BDANetworkProvider=@devicew:{71985F4B-1CA1-11D3-9CC8-00C04F7971E0}\Microsoft ATSC Network Provider
BDAOffset=166
BDAReceiver=
BDAScanFreqEnd=858000
BDAScanFreqStart=474000
BDATuner=
BDAUseOffset=0
LastChannel=1
[Favorites]
RelativeDrive=0
RememberPosition=1
[FileFormats]
3g2=3g2 3gp2
3gp=3gp 3gpp 3ga
ac3dts=ac3 dts dtshd
aiff=aif aifc aiff
alac=alac
amr=amr awb
ape=ape apl
au=au snd
audiocd=cda
avi=avi divx
bdpls=mpls bdmv
bink=smk bik
cue=cue
dsd=dsf dff
dsm=dsm dsv dsa dss
dvdaudio=aob
dvdvideo=vob ifo
flac=flac
flic=fli flc flic
flv=flv f4v
m4a=m4a m4b aac
midi=mid midi rmi
mka=mka
mkv=mkv mk3d
mlp=mlp
mov=mov
mp3=mp3
mp4=mp4 m4v mp4v mpv4 hdmov ismv
mpa=mpa mp2 m1a m2a
mpc=mpc
mpeg=mpg mpeg mpe m1v m2v mpv2 mp2v pva evo m2p sfd
mpegts=ts tp trp m2t m2ts mts rec ssif
ofr=ofr ofs
ogg=ogg oga
ogm=ogm ogv
opus=opus
other=amv wtv dvr-ms mxf ivf
pls=asx m3u m3u8 pls wpl mpcpl xspf
ra=ra
rawvideo=y4m h264 264 vc1 h265 265 hm10 hevc
rm=rm ram rmm rmvb
roq=roq
speex=spx
swf=swf
tak=tak
tta=tta
wav=wav w64
wavpack=wv
webm=webm
wma=wma
wmv=wmv wmp wm asf
[InternalFilters]
adec_aac=1
adec_ac3=1
adec_alac=1
adec_als=1
adec_amr=1
adec_ape=1
adec_bink=1
adec_dsd=1
adec_dts=1
adec_flac=1
adec_indeo=1
adec_lpcm=1
adec_mpa=1
adec_musepack=1
adec_nelly=1
adec_opus=1
adec_pcm_adpcm=1
adec_ps2=1
adec_qdm2=1
adec_qdmc=1
adec_real=1
adec_shorten=1
adec_speex=1
adec_tak=1
adec_truespeech=1
adec_tta=1
adec_vorbis=1
adec_voxware=1
adec_wavpack=1
adec_wma=1
adec_wma9=1
adec_wmalossless=1
adec_wmavoice=1
src_amr=1
src_ape=1
src_avi=1
src_bink=1
src_cdda=1
src_cdxa=1
src_dsd=1
src_dsm=1
src_dtsac3=1
src_flac=1
src_flic=1
src_flv=1
src_matroska=1
src_mp4=1
src_mpa=1
src_mpeg=1
src_musepack=1
src_ogg=1
src_rawvideo=1
src_real=1
src_roq=1
src_shoutcast=1
src_stdinput=1
src_tak=1
src_tta=1
src_udp=1
src_vts=1
src_wav=1
src_wavpack=1
vdec_amv=1
vdec_bink=1
vdec_canopus=1
vdec_cineform=1
vdec_cinepak=1
vdec_dirac=1
vdec_divx=1
vdec_dnxhd=1
vdec_dv=1
vdec_dxva_h264=1
vdec_dxva_hevc=1
vdec_dxva_mpeg2=1
vdec_dxva_vc1=1
vdec_dxva_vp9=1
vdec_dxva_wmv3=1
vdec_flv=1
vdec_h263=1
vdec_h264=1
vdec_h264_mvc=0
vdec_hevc=1
vdec_indeo=1
vdec_libmpeg2_mpeg1=1
vdec_libmpeg2_mpeg2=1
vdec_lossless=1
vdec_mjpeg=1
vdec_mpeg1=1
vdec_mpeg2=1
vdec_msmpeg4=1
vdec_png=1
vdec_prores=1
vdec_qt=1
vdec_real=1
vdec_screen=1
vdec_svq=1
vdec_theora=1
vdec_uncompressed=1
vdec_ut=1
vdec_vc1=1
vdec_vp356=1
vdec_vp789=1
vdec_wmv=1
vdec_xvid=1
[Recent File List]
File1=C:\Users\test1\Downloads\The.Big.Bang.Theory .S10E09.720p.HDTV.x265.ShAaNiG.mkv
File10=C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\the.big.bang.the ory.1003.hdtv-lol[ettv].mkv
File11=C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\the.big.bang.the ory.1002.hdtv-lol[ettv].mkv
File12=C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\The.Big.Bang.The ory.S10E01.720p.HDTV.2CH.x265.HEVC-PSA.mkv
File13=T:\New folder\ts\bbt\New folder (9)\The.Big.Bang.Theory.S09E23.720p.HDTV.x265.ShAa NiG.mkv
File14=T:\New folder\ts\bbt\New folder (9)\The.Big.Bang.Theory.S09E22.720p.HDTV.x265.ShAa NiG.mkv
File15=C:\Users\test1\Downloads\Video\Marvels.Agen ts.of.S.H.I.E.L.D.S04E09.720p.HDTV.x265.ShAaNiG.mk v
File16=C:\Users\test1\Documents\Lynda - PowerPoint 2016 Essential Training\04. Working with Slides\04_01-Adding and removing slides.mp4
File17=C:\Users\test1\Documents\Lynda - PowerPoint 2016 Essential Training\04. Working with Slides\04_03-Organizing slides into sections.mp4
File18=T:\New folder\ts\bbt\New folder (9)\The.Big.Bang.Theory.S09E21.720p.HDTV.x265.ShAa NiG.mkv
File19=C:\Users\test1\Downloads\Video\Sherlock.S04 E02.720p.HDTV.x265.ShAaNiG.mkv.mp4
File2=C:\Users\test1\Downloads\The.Big.Bang.Theory .S10E08.720p.HDTV.x265.ShAaNiG.mkv
File20=T:\New folder\ts\bbt\New folder (9)\The.Big.Bang.Theory.S09E20.720p.HDTV.x265.ShAa NiG.mkv
File3=C:\Users\test1\Downloads\From [ WWW.TORRENTING.ME ] - The.Blacklist.S04E10.720p.HEVC.x265-MeGusta\The.Blacklist.S04E10.720p.HEVC.x265-MeGusta.mkv
File4=C:\Users\test1\Downloads\The.Big.Bang.Theory .S10E07.720p.HDTV.x265.ShAaNiG.mkv
File5=C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\The.Big.Bang.The ory.S10E06.720p.HDTV.x265.ShAaNiG.mkv
File6=C:\Users\test1\Documents\Installed Softwares\Bittorent\DownloadsPath\The.Big.Bang.The ory.S10E05.720p.HDTV.x265.ShAaNiG.mkv
File7=http://localhost:65046/0
File8=T:\New folder\ts\bbt\New folder (9)\The.Big.Bang.Theory.S09E24.720p.HDTV.x265.ShAa NiG.mkv
File9=C:\Users\test1\Downloads\Video\The.Big.Bang. Theory.S10E04.720p.HDTV.x265.ShAaNiG.mkv.mp4
[RecentFiles]
DVD1=00000000000000000000000000000000
DVD10=00000000000000000000000000000000
DVD11=00000000000000000000000000000000
DVD12=00000000000000000000000000000000
DVD13=00000000000000000000000000000000
DVD14=00000000000000000000000000000000
DVD15=00000000000000000000000000000000
DVD16=00000000000000000000000000000000
DVD17=00000000000000000000000000000000
DVD18=00000000000000000000000000000000
DVD19=00000000000000000000000000000000
DVD2=00000000000000000000000000000000
DVD20=00000000000000000000000000000000
DVD3=00000000000000000000000000000000
DVD4=00000000000000000000000000000000
DVD5=00000000000000000000000000000000
DVD6=00000000000000000000000000000000
DVD7=00000000000000000000000000000000
DVD8=00000000000000000000000000000000
DVD9=00000000000000000000000000000000
[Settings]
AccelTblColWidth=BABEBAAAAAHOAAAAAAODAAAAAAFKAAAAA APJAAAAAALNAAAAAADHAAAAAAJEAAAAAA
AddSimilarFiles=1
AspectRatioX=0
AspectRatioY=0
AssociatedWithIcon=0
AudioAutoVolumeControl=0
AudioBassRedirect=0
AudioGain=0.0
AudioLang=2057
AudioMixer=0
AudioMixerLayout=2.0
AudioNormBoost=1
AudioNormLevel=75
AudioNormRealeaseTime=8
AudioPaths=.;.\audio;.\fandub
AudioRendererType=
AudiosLanguageOrder=
AudioTimeShift=0
AudioWindowMode=1
AutoFitFactor=50
AutoloadAudio=1
AutoReloadExtSubtitles=1
AutoZoom=0
Balance=0
BufferDuration=3000
ChapterMarker=0
ClosedCaptions=0
ColumnDelta=0
CompMonDeskARDiff=0
ControlLimit=AAAAAAAAAAAAAAAE
ControlState=3
CycleDelta=AAAAAAAEKCJKDFPD
D3D9RenderDevice=
D3DFullScreen=0
DefaultCapture=0
DefaultVideoFrame=6
DisableInternalSubtitles=0
DisplayModeChangeDelay=0
DlgPropX=53
DlgPropY=140
DontUseSearchInFolder=0
Downscaler=1
DSVidRen=11
DualAudioOtput=0
DVDPath=
DX9Resizer=1
DX9SurfaceFormat=22
DX9TenBitOutput=0
EnableAudioTimeShift=0
EnableEDLEditor=0
EnableSubtitles=1
EnableWebServer=0
EnableWorkerThreadForOpening=1
EVRBuffers=5
EVREnableFrameTimeCorrection=0
EVROutputRange=0
ExitAfterPlayBack=0
ExitFullscreenAtFocusLost=0
ExitFullscreenAtTheEnd=1
FastSeek=1
FileNameOnSeekBar=1
ForcedSubtitles=0
FullScreenCtrls=1
FullScreenCtrlsTimeOut=0
FullScreenMonitor=Current
FullScreenMonitorID=LGD039F
FullscreenRes=AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAABABAGFFAAAAAAADAAAAAACAAAAAAMDAAAAAAAAAAAAAABA GGGGGGGGGGGGHDAECEAGFOANCCLPHDAEBABAGFFAAAAAAADAAA AAACAAAAAAMDAAAAAAAAAAAAAABAIAMKMBKFEGLPHDAEJDELIM GHOLPHIDAEBABAGFFAAAAAAADAAAAAACAAAAAAMDAAAAAAAAAA AAAABAAAAAAAAAAAAIIDAEJDELIMGHOLPHJDAEBABAGFFAAAAA AADAAAAAACAAAAAAMDAAAAAAAAAAAAAABAAAAAAAAAAAAINDAE CEAGFOANCCLPNDAEBABAGFFAAAAAAADAAAAAACAAAAAAMDAAAA AAAAAAAAAABAIAMKMBKFEGLPNDAEJDELIMGHOLPHODAEBABAGF FAAAAAAADAAAAAACAAAAAAMDAAAAAAAAAAAAAABAAAAAAAAAAA AMIEAENBKFEGLDPNPDJEAEBABAGFFAAAAAAADAAAAAACAAAAAA MDAAAAAAAAAAAAAABAAAAAAAAAAAAMNEAEJCMFPICMFPIPNEAE BABAGFFAAAAAAADAAAAAACAAAAAAMDAAAAAAAAAAAAAABAMACA LCHIGBJPNEAENBKFEGLDPNPDOEAEBABAACDAAAAAIFCAAAAAAC AAAAAAICAAAAAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
HideCaptionMenu=0
HideCDROMsSubMenu=0
HideNavigation=0
HidePlaylistFullScreen=0
IntRealMedia=0
ISDb=www.opensubtitles.org/isdb
JumpDistL=20000
JumpDistM=5000
JumpDistS=1000
KeepAspectRatio=1
KeepHistory=1
Language=en
LastFileInfoPage=10053
LastOpenDir=C:\
LastOpenFilterDir=
LastSavedPlaylistDir=C:\
LastUsedPage=10064
LastWindowRect=LMAAAAAAIFAAAAAAONDAAAAAEMCAAAAA
LastWindowType=0
LaunchFullScreen=0
LcdSupport=0
LimitWindowProportions=0
LineDelta=0
LogoExt=0
LogoFile=
LogoID2=208
Loop=0
LoopNum=1
MenuLang=2057
MiniDump=0
MultipleInstances=2
Mute=0
OnTop=3
OSD_Font=Segoe UI
OSD_RemainingTime=0
OSD_Size=18
OSDBorder=1
OSDFontAA=1
OSDFontColor=14737632
OSDFontShadow=0
OSDGrad1Color=3156000
OSDGrad2Color=3156000
OSDTransparent=100
PasteClipboardURL=0
PauseMinimizedVideo=1
PreventMinimize=0
PrioritizeExternalAudio=0
PrioritizeExternalSubtitles=1
Priority=32768
RecentFilesNumber=20
RemainingTime=0
Remember DVD Pos=1
Remember File Pos=1
RememberPlaylistItems=1
RememberWindowPos=1
RememberWindowSize=1
ReportFailedPins=1
ResetDevice=1
RestoreResAfterExit=1
Rewind=0
SearchInDirAfterPlayBack=0
SearchInDirAfterPlayBackLooped=0
SecondAudioRenderer=
ShaderList=
ShaderListScreenSpace=
Shaders List=
ShowContextDir=0
ShowContextFiles=0
ShowOSD=3
ShufflePlaylistItems=0
SmartSeekSize=15
SnapShotPath=C:\Users\test1\Pictures\
SnapToDesktopEdges=1
SPCAllowAnimationWhenBuffering=1
SPCAllowDropSubPic=1
SPCSize=10
SPDefaultStyle=20;20;20;20;2;0;2.000000;2.000000;3 .000000;3.000000;0xffffff;0x00ffff;0x000000;0x0000 00;0x00;0x00;0x00;0x80;0;Segoe UI;20.000000;100.000000;100.000000;0.000000;700;0; 0;0;0;0.000000;0.000000;0.000000;0.000000;2
SpeedStep=0
SPHorPos=50
SPMaxTexRes=1280
SPOverridePlacement=1
SPVerPos=100
Start Main Title DVD=0
Stereo3DMode=0
Stereo3DSwapLeftRight=0
SubDelayInterval=500
SubpicStereoMode=0
SubSaveExternalStyleFile=0
SubtitlePaths=.;.\subtitles;.\subs;.\sub
SubtitleRenderer=1
SubtitlesLang=2057
SubtitlesLanguageOrder=
SyncControlLimit=AAAAAAAAAAAAAAAE
SyncCycleDelta=BGCDFFADKCJKDFPD
SynchronizeMode=0
SyncTargetOffset=AAAAAAAAAAAAICAE
TargetSyncOffset=AAAAAAAAAAAAICAE
ThemeBlue=255
ThemeBrightness=15
ThemeGreen=255
ThemeRed=255
ThumbCols=4
ThumbLevelPNG=7
ThumbQuality=85
ThumbRows=4
ThumbWidth=1024
TimeTooltipPosition=0
TitleBarTextStyle=1
TitleBarTextTitle=0
ToggleShader=0
ToggleShaderScreenSpace=0
Toolbar clrFace(ABGR)=16777215
Toolbar clrOutline(ABGR)=8816262
TrayIcon=0
UICEAddr=127.0.0.1:1234
UseDarkTheme=1
UseDefaultsubtitlesStyle=0
UseDVDPath=0
UseFlybar=1
UseFlybarOnTop=0
UseGlobalMedia=1
UseInternalSelectTrackLogic=1
UseSmartSeek=0
UseSubresync=0
UseTimeTooltip=1
UseUICE=0
UseWin7TaskBar=1
UseWinLirc=0
VideoBrightness=0
VideoContrast=0
VideoHue=0
VideoSaturation=0
VMRAlternateVSync=0
VMRColorManagementAmbientLight=0
VMRColorManagementEnable=0
VMRColorManagementInput=0
VMRColorManagementIntent=0
VMRDisableDesktopComposition=0
VMRFlushGPUAfterPresent=0
VMRFlushGPUBeforeVSync=0
VMRFlushGPUWait=0
VMRMixerMode=1
VMRMixerYUV=1
VMRVSync=0
VMRVSyncAccurate2=0
VMRVSyncOffset=0
Volume=35
VolumeStep=5
WebDefIndex=index.html;index.php
WebRoot=*./webroot
WebServerCGI=
WebServerLocalhostOnly=0
WebServerPort=13579
WebServerPrintDebugIfo=0
WebServerQuality=85
WebServerUseCompression=1
WinLircAddr=127.0.0.1:8765
Youtube60fps=0
YoutubeFormat=MP4
YoutubeHDR=0
YoutubeLoadPlaylist=0
YoutubePageParser=1
YoutubeResolution=360
Zoom=1
[Settings\Filters Priority]
avi={00000000-0000-0000-0000-000000000000}
flv={00000000-0000-0000-0000-000000000000}
http={00000000-0000-0000-0000-000000000000}
mkv={00000000-0000-0000-0000-000000000000}
mp4={00000000-0000-0000-0000-000000000000}
mpeg={00000000-0000-0000-0000-000000000000}
mpegts={00000000-0000-0000-0000-000000000000}
wmv={00000000-0000-0000-0000-000000000000}
[Settings\PnSPresets]
Preset0=Scale to 16:9 TV,0.500,0.500,1.000,1.333
Preset1=Zoom To Widescreen,0.500,0.500,1.333,1.333
Preset2=Zoom To Ultra-Widescreen,0.500,0.500,1.763,1.763
[Settings\Updater]
UpdaterAutoCheck=0
UpdaterDelay=7
UpdaterLastCheck=AAAAAAAAAAAAAAAA
[Settings\Video]
ColorManagement=0
Downscaler=1
EVRBuffers=5
EVROutputRange=0
FlushGPUWait=0
Output10Bit=0
RenderDevice=
ResetDevice=0
Resizer=1
SubpicAllowDrop=1
SubpicAnimationWhenBuffering=1
SubpicCount=10
SubpicMaxTexWidth=1280
SubpicStereoMode=0
SurfaceFormat=22
SyncColumnDelta=0
SyncLineDelta=0
SyncMode=0
VideoRenderer=3
VMRMixerMode=1
VMRMixerYUV=1
VSync=0
VSyncAccurate=0
VSyncAlternate=0
VSyncOffset=0
[ToolBars\Capture Settings]
DockState=59420
[ToolBars\Capture Settings\State-SCBar-825]
sizeFloatCX=191
sizeFloatCY=470
sizeHorzCX=191
sizeHorzCY=470
sizeVertCX=191
sizeVertCY=470
[ToolBars\Edit List Editor]
DockState=59421
[ToolBars\Edit List Editor\State-SCBar-846]
sizeFloatCX=200
sizeFloatCY=100
sizeHorzCX=200
sizeHorzCY=100
sizeVertCX=200
sizeVertCY=100
[ToolBars\Navigation Bar]
DockState=59420
[ToolBars\Navigation Bar\State-SCBar-1009]
sizeFloatCX=225
sizeFloatCY=496
sizeHorzCX=225
sizeHorzCY=496
sizeVertCX=225
sizeVertCY=496
[ToolBars\Playlist]
DockState=59422
Visible=0
[ToolBars\Playlist\State-SCBar-824]
sizeFloatCX=200
sizeFloatCY=100
sizeHorzCX=1370
sizeHorzCY=100
sizeVertCX=200
sizeVertCY=100
[ToolBars\Shader Editor]
DockState=59419
[ToolBars\Shader Editor\State-SCBar-826]
sizeFloatCX=308
sizeFloatCY=115
sizeHorzCX=1370
sizeHorzCY=115
sizeVertCX=308
sizeVertCY=115
[ToolBars\Subresync]
DockState=59419
[ToolBars\Subresync\State-SCBar-823]
sizeFloatCX=200
sizeFloatCY=200
sizeHorzCX=200
sizeHorzCY=200
sizeVertCX=200
sizeVertCY=200
Results 1 to 1 of 1
The x265 HEVC Upgrade
By x265 in forum Software PlayingReplies: 18Last Post: 20th Oct 2019, 02:19 -
x265 HEVC Encoder
By x265 in forum Video ConversionReplies: 781Last Post: 2nd Aug 2019, 01:28 -
[HEVC] x265 Parameter Reconfiguration
By Italoplk in forum ProgrammingReplies: 1Last Post: 14th Jan 2017, 13:50 -
HEVC-x265 player in linux?
By racer-x in forum LinuxReplies: 4Last Post: 20th Mar 2014, 18:10 -
HEVC x265 Decoder
By enim in forum Newbie / General discussionsReplies: 5Last Post: 19th Aug 2013, 12:58
