Because this is the only logical page I could find which states ALL the numbers correctly for various devices that Hauppague produced with same confusing names...
And these old devices do go for peanuts on fleebay...
As to splitter, another few quid. So all in all less than two rounds of beer with couple of mates...
And NO VHS is worth all the fuss. It is bad quality no matter what. There is no magic that the end result will be any better (no matter what one thinks or believes)
Results 31 to 36 of 36
No argument there. No matter what equipment you use to capture it, you're ultimately limited by the quality of the original recording and the age of the tape. There comes a point beyond which you're just not going to improve the capture. (There is some post-processing you can do to improve the video after it's captured, however. Even so, that's just repainting an old barn.) Nevertheless, you have to decide how much money you are willing to throw at it, and you do the best you can with what you can get for the money.
As for my own VHS collection, I have maybe 100 or so tapes that I recorded off cable back in the 1990s. With the tapes being that old, I'm already expecting some signal degradation. And I'd have to buy a new VCR to do anything. My old one blew up (quite literally – the house reeked of smoke and melted plastic for a week) when my Mom was trying to watch a movie on new year's eve about 5 years ago, and I've never gotten around to replacing it. With the exception of a few old movies that aren't available on DVD, I doubt I have any tapes that are worth the time to convert to digital. All the commercial tapes I had I have already replaced with commercial DVDs.Do or do not. There is no "try." - Yoda -
Maybe just terminology but how can Composite video be "a stream"? It's analog video, it's not a stream of 0's and 1's, unlike HDMI.
I disagree with your statement – the HDMI output would allow you to capture without having another conversion from digital to analog and back, while if you used the Composite output the video would run through those two conversions which is never lossless. And although there shouldn't be major differences because of that, the two are not the same. Now you could say for VHS such small losses don't matter, but I'm not going to decide what is good enough.
My point is, if the VCR runs the VHS signal through it's digital processing no matter what (and I bet it does) then there is no point at all in not using the HDMI output (at 480i/576i). Anything the unit outputs via Composite would be just a conversion to analog of the very same stream that you could copy losslessly via HDMI to your HDD. Unless the Composite output is linked directly to the VHS part of the unit without first running through any digital processing (so basically like any plain VCR without TBC and digital NR) there is simply no way a capture over Composite can be any better than over HDMI.
Why would capturing 480p/576p be any better over 480i/576i? All the VCR does is it takes the digitizted VHS video and runs it through it's real time deinterlacer. I would avoid that like the plague.
Maybe I don't get it but that doesn't make sense to me.Last edited by Skiller; 5th Apr 2017 at 04:26.
Maybe I should have said "the HDMI would give you the same image as the composite signal" (since they're both interlaced). But you're not disagreeing with me, as I also think it's better to just use the HDMI output since it's already there. I was making the comparison because someone else had said it would be better to use the composite output.
Now that I go back and think about it, the 480i/576i HDMI stream shouldn't have that problem, since it's already gone through the internal TBC. It's recording the composite video without a TBC that would have that problem.
Of course, all of this is based on the assumption that the VCR actually does have an internal Time-Base Corrector, and that the digital output is therefore correctly synchronized to the analog fields/frames.Do or do not. There is no "try." - Yoda -
No one can be sure how that HDMI VCR handles the capturing and processing of the video VS a stand alone S-VHS TBC/DNR deck connected to a capture device from the late 90's and early 2000's, The only way for the OP to tell the difference is to experiment himself if there is few tapes that are worth the adventure.
Sorry I was confusing statements.
Because I want to capture what's on the tape in it's rawest form, with as few processing as possible before it gets on my HDD (apart from jitter correction, nothing should be done to it imo). And, later, I can have better deinterlacing in software than the real timer deinterlacer of the HDMI output can provide.
But TBC and deinterlacer are not tied together. Any kind of TBC functionality is due to the (more intelligent) way the sampling process in the conversion from analog to digital is done (yes, that's all the magic). On the tape there is 480i/576i stored, more precisely there are 59.94 or 50 fields per second, each video head reads either the odd or the even fields.
A deinterlacer just takes those fields after the conversion to digital (so after the TBC) and interpolates the missing lines of each field in some more or less smart way to turn the fields into full height frames.
In other words, you do not gain anything by having the hardware do this for you, except maybe time. I'm not saying you should not deinterlace, I just would not do it during the capture, but afterwards in software.
All of that is however relying on the quality of the hardware deinterlacer because there are and always will be only mentioned fields to capture from VHS.
But only if the analog VCR part is linked to the Composite out without running through it's digital processing first. And I'm pretty sure it doesn't do that because otherwise the engineers would have had to implement an additional circuit to route the original analog video to the Composite out – and for what purpose?!
This means you are getting the same processing on all outputs of the unit, for the the analog outputs the stream is converted to analog again after all the processing.
And if it didn't have TBC-like functionality, the only difference would be that the analog defects would be baked in forever into the video, but the output signals would still be continuous and stable – it cannot be any different since the video had to be converted to digital for the unit to do it's processing and signal instabilities and discontinuities get lost at that point – it just doesn't imply they also get corrected visibly(!).Last edited by Skiller; 5th Apr 2017 at 05:40.
VHS to hard drive, via HDMI . . . how?
By engineerer in forum Capturing and VCRReplies: 18Last Post: 14th Jan 2015, 15:33 -
Capturing HDMI from an iPad 3
By SenorKaffee in forum Capturing and VCRReplies: 5Last Post: 5th Jan 2015, 20:02 -
Capturing with hdmi input
By prolific in forum Capturing and VCRReplies: 1Last Post: 29th Jun 2013, 14:17 -
Capturing HDTV to MAC via (HDMI to USB)
By legionar2010 in forum MacReplies: 4Last Post: 10th Feb 2013, 08:48 -
Splitting HDMI and capturing?
By DragonTorso in forum Capturing and VCRReplies: 11Last Post: 4th Aug 2012, 11:18
