CAN ANY1 TELL ME WHAT TOOLS TO USE TO PUT A LOGO ON A MPEG FILE, AND WHERE CAN I GET LOGOS TO MAKE MY OWN VCD WITH MY LOGO ON IT,MAY I SAY ALL THOSE ENCODERS ARE NOT GOOD,LETS FACE IT THERE HAS TO BE BETTER,DOSENT MATTER WHAT YOU DO{TMPGE}CRAP FOR MULTIPLEXING.<LSX>TOO DAMM LONG<PANASONIC>CRAP.....ROXIO,-QUALITY IS CRAP>THERE HAS TOO BE A GOOD ENCODER,IF SO TELL ME :roll:
I use Logo plugin for virtualdub. It works well for me.
This is what I do:
Load AVI in virtualdub, add Logo filter (change settings as required) and frameserve to TMPGenc.
For more information and download go to:
http://sauron.mordor.net/dgraft/logo.html -
scotuk1,
U sure R a frusted one, R ya?
hasn't anyone ben able to help you out with your particular encoding
problem? ...or do you have many?
There R so many guides on this website thta you can try. Shorly you
haven't tried them all allready, have you? And none of them work?
When you say CRAP, how do the crap look?
* Is your source a divX or DVD or Captured source ie VHS ?
* And, what R you talking about Crap wise, VCD or SVCD??
Anyways, have you tired the
* tmpg templates ??
* seen some of the http://<b><a class="contentlink" href="http://www.vcdhelp.com/vcdtools.htm#samples" ta...amples</a></b> ??
* tried any OTHER http://<b><a class="contentlink" href="http://www.vcdhelp.com/vcdtools.htm#players" ta...layers</a></b> ??
WinDVD 3.0 player VCDs better than powerdvd
WinDVD also plays SVCDs better too, but powerdvd player SVCD pretty
good, but NOT the VCDs.
TMPG doesn't have a LOGO filter for you to add your own logo.
But, vdub has one (filterwise):
* logo (1.3. beta 4)
...in short, it'll be like crap to you too, but at least
it works. But, it can come out nice IF you use it correctly.
I've used it. Took some getting use to, but it does work, not that
great, but does work.
-vhelp
Adding logo
By kenryuakuma in forum Newbie / General discussionsReplies: 0Last Post: 4th Nov 2011, 01:49 -
Adding Overlay Or Logo
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 28th Nov 2008, 13:38 -
Adding Logo's in FCP
By James in HD in forum MacReplies: 11Last Post: 13th Jan 2008, 20:28 -
Adding logo
By shashidar in forum EditingReplies: 2Last Post: 10th Jan 2008, 18:39 -
adding logo/watermark using tmpgenc
By Bytez in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 15:25
