Results 1 to 17 of 17
    Jan 2017
    Italia
    Hi, i'm encoding (x265) some anime Blu Rays with Hybrid, I'm relatively new to video editing and the source has this noise that I don't really know how to remove.
    I'd like to have perfectly flat colors, if I can remove it or at least reduce it with an Hybrid filter or an avs script, how do I do it?
    source info
    Screenshot from the source
    close up
Name:	Immagine - Copia.png
  2. It would be much better for you to post a 10 second sample and not just a picture. A sample with steady movement because I doubt the framerate is really 29.97fps.
    And you downloaded this, didn't you? So it's not really a Blu-Ray, is it? And it's already been reencoded by someone?
  3. You can reduce the noise (you may lose some detail too) but you'll have to upload a sample (not reencoded) of the source. Also be aware that removing the noise may lead to posterization.
    Jan 2017
    Italia
    Yes, I downloaded it, I had no choice for a number of reasons, but I can ensure you this is a blu ray and it's not been reencoded.
    I'll post a sample as soon as possible.
  5. dfttest and deen filters work great for noise in animes
    Jan 2017
    Italia
    Thank you, if you can, can you please give me the parameters I've to set, based on the sample I uploaded?
  7. Originally Posted by ThePi7on View Post
    That's a terrible sample. It's not representative of the body of the show. And it doesn't have much in the way of dark areas where the noise shows up most.
  8. The grain in the background sky is intentional. Is that what you're trying to get rid of? There is a little bit of mosquito noise around the dark lines in the character animation. You can eliminate most of that with Deen(mode="a3d", rad=1, thrY=2, thrUV=3). But that also blurs the thin lines in the guy's hair. You can raise the threshold values and radius in Deen to get more noise reduction but watch out for blurring of other details and posterization (banding) artifacts.
    Jan 2017
    Italia
    It's not that noise that I want to get rid of. It's the noise that you see in all the black space in the guy's hair in the second clip. I'm fine with the noise around the lines an in the background.
  10. Originally Posted by ThePi7on View Post
    I just wanted to be sure. You can use Histogram(mode="luma") to accentuate the noise and test your filtering.
    LWLibavVideoSource("sample2.m2ts")
    src = last
    Deen(mode="a3d", rad=1, thrY=1, thrUV=1)
    Interleave(src,last) # show before and after
    Histogram(mode="luma") # show noise
    Deen there is sufficient to get rid of most of that noise.
    Jan 2017
    Italia
    src = last
    Thank you very much. Newbie question, when I try to play it on mpchc it doesn't recognize LWLibavVideoSource, I assume it's a plugin, but I can't find a download link for it, where do I download it?
  12. LWLibavVideoSource is a part of the LSMASH package.
    http://avisynth.nl/index.php/LSMASHSource
    Note that the script interleaves frames of the source and filtered video then uses Histogram() to show the noise. If you want to just see the before and after images, remove the last line. If you want to see just the results, remove the last two lines.
    Jan 2017
    Italia
    Works great, thank you for you time.
