  1. I use Dxtory to record video games and I need audio codec to be able to record 5.1 audio, but pretty much all codecs I have(AC3ACM, Lame MP3, PCM, etc.) allow me to record only stereo. I can record 5.1 audio using IEEE Float but it's like ~8GB per 1 hour of recording. For example, when I use Lame MP3, it's only ~800 MB per 1 hour of recording(sure, it's only 2 channels against 6, but still).
    Recommend some audio codec I can use to record 5.1 audio, please.
  2. Originally Posted by KulaGGin View Post
    Even AC3-ACM only stereo?
  3. Originally Posted by sneaker View Post
    Yes, unfortunately even AC3-ACM allows me to record only in stereo mode(it downmix to stereo):
    https://forum.videohelp.com/images/imgfiles/tY7zdyc.png
    I can't find any working ACM versions of AAC, though . I tried to install AAC-ACM, but it doesn't appear in the list of Dxtory, because I need encoder, when atm it can only decode...
    Sep 2012
    Australia
    From the looks of things the program uses VFW codecs...
    I think VirtualDub uses the same API...
    According to my Virtualdub, of the audio codecs I have installed, AC-3 and DTS can be encoded into 5.1.
    As far as I'm aware, all I have installed is this:
    https://www.videohelp.com/software/Win7codecs
    Although there may be another program on my system that put them there.
  5. Originally Posted by ndjamena View Post
    When I installed AC3-ACM manually, it showed on Dxtory after restarting it:
    https://forum.videohelp.com/images/imgfiles/XORDkqz.png
    Yes, it can, because standards themselves allows you to, right?
    I have installed this Advanced Codecs software, but nothing changed on my Dxtory list of audio codecs:
    https://forum.videohelp.com/images/imgfiles/245kKd3.png
    Too sad that true surround sound is so uncommon, so it's so hard to find proper codec...
    Is there some kind of mega-pack of ACM/DirectShow/VFW codecs or whatever?
    Sep 2012
    Australia
    The list of codecs VirtualDub is showing me is almost identical to the list in your image, except mine has DTS and AC-3 added.
    I honestly have no idea where they came from, it could have come from anywhere, I can only hope someone on the forum can tell you (assuming they'd be compatible with your program anyway).
    Have you tried restarting the PC... it may be a waste of time but it's all I can think of.
    You could try downloading VirtualDub to see what's it puts in your audio codec list, just to find out if I'm off the mark here.
