    Dec 2016
    at Home
    The time of the source file is a different one after loading in VidCoder 2.4.4 (see pics). There is always something missing from the end of the film. My mistake, or a bug?
    They are .ts.files that were cut with TS-Doctor.
    Thanks for help.
    Best regards,
    Micky
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Or an issue with the source file.
    Google is your Friend
    Dec 2016
    at Home
    The problem is however only in vidcoder and handbrake
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    VidCoder is a gui for handbrake, so it makes sense that they would both have the same issue.
    The only time I've had similar issues was with DVD rips, and it was a byproduct of how the discs were ripped.
    In any case, it would appear you answered your question. If you are only seeing the problem with this software, then it's an issue with this software. I don't know what else you want to hear.
    Dec 2016
    at Home
    Hear nothing, but have hoped for a solution . Had this error again (not always, but too much for me).
    Now have a other FFmpeg frontend and it works very well.
    Regrads,
    Micky
