Hi
Let's say you have two audio files at different volumes. They both have dialogue, but clip B has intermittent background noise that hits peaks eg. gunshots/explosions. How would you match the volume of the dialogue in clip B with that of clip A so that at least during the silent moments where there are no peaks, they will be at the exact same volume?
Will the gunshots only affect the matching process at that instance in the clip?
I started my trial of Adobe Audition 2017 so I can use it if your solution involves using it.
Run Audition's "amplitude stats" on clip A and note the average. Select the longest stretch of B that has dialogue but no peak effects and run amplitude stats on it. Find the difference from Clip A and amplify or fade to match. Tweak to suit your ears as necessary. If you want to be more sophisticated about it, try the LUFS Meter VST plugin.
Is this using Adobe Audition? Will the amplitude stats give a dB reading and then it's just a simple volume increase ?
That's how it works in Audition 3. Hopefully it's still there in Audition 2017.
Why does ffmpeg audio volume cmd -af "volume=50dB" not work?
By pxstein in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2013, 10:21 -
Matching color temperatures
By diprotic in forum RestorationReplies: 39Last Post: 3rd Nov 2013, 11:09 -
Dialogue Volume in LCD TV is low while action/music volume is high
By Biker Biker in forum DVB / IPTVReplies: 4Last Post: 2nd Mar 2013, 01:41 -
Matching frames of HQ and LQ video
By Mephesto in forum EditingReplies: 6Last Post: 30th Sep 2012, 11:47 -
Chroma shift after field-matching
By drawar in forum EditingReplies: 4Last Post: 25th Apr 2012, 04:07
