  1. Hi!
    I want to try the kvazaar encoder, and does'nt find some information for the parameters. For example, how to setting up the crf, the qcomp and other arguments? If i have an options for x265 like this:
    ffmpeg \
    -i "input.mkv" \
    -c:v libx265 \
    -pix_fmt yuv420p10le \
    -preset medium \
    -x265-params \
    crf=21:\
    qcomp=0.65:\
    max-tu-size=16:\
    aq-mode=1:\
    aq-strength=1.0:\
    psy-rd=0.7:\
    psy-rdoq=5.0:\
    rdoq-level=1:\
    merange=50:\
    rc-lookahead=80:\
    sao=0:\
    rect=0:\
    amp=0:\
    strong-intra-smoothing=0 \
    how to transfer for kvazaar?
    Thank you.
  2. Member leghorn's Avatar
    Apr 2007
    Germany
    Don't always use Google. I looked kvazaar encoder up with DuckDuckGo and came to a site called hub.docker.com. There you can find information. Although I guess you might even get there from the Ultra Video homepage.
    Das Leben ist eine Nebelwand voller Rasierklingen. (C. Bukowski)
