How do I do it?! I currently use MakeMKV to rip the Blu Ray disc.
				Results 1 to 12 of 12
	Choose x264 encoder. Set "Preset" according to the encoding time you are willing to spend. "Medium" is a good start. Then set quality using "RF", "18" will give good quality (lower RF value = better quality = bigger file). Set "Profile" to "High". For BluRay you usually want to set "Framerate" to "Same as source" + "Constant Framerate". Audio tracks to "Auto-Pass Thru" to keep audio untouched.
 Further info see the "technical documentation" on the HandBrake website.
 https://handbrake.fr/docs/en/latest/
	What produces the best quality....encoder set to fast or encoder set to slow?
	They can achieve the same quality but for a given quality fast will need more disk space.
	Why does it it say 'Warning' RF 0 is lossless if its set to zero?
	Lossless files will be extremely huge, larger than the original BluRay even. That's why it's warning you. Sane settings are in the range of 16 to 23. Start with 18 and decide if it's good enough.
  MKV Compression to a smaller MKV or MP4By THRobinson in forum Video ConversionReplies: 9Last Post: 20th Jul 2018, 11:56
  Convert .TS file with subtitle to MP4 or MKVBy Cazz in forum Video ConversionReplies: 19Last Post: 4th Feb 2017, 17:51
  [Q] Blu-ray to MKV to MP4... How to keep HD and smallER file sizeBy Varxtis in forum Blu-ray RippingReplies: 6Last Post: 27th Sep 2013, 19:15
  MP4 container smaller than MKV?By JamesWade in forum Video ConversionReplies: 4Last Post: 15th Dec 2012, 11:34
  Xvid vs x264 -- Bit Rate: 1900 kbps -- Same quality but smaller x264 file?By kingaddi in forum DVD RippingReplies: 17Last Post: 2nd Sep 2012, 12:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
