Hi there,
After doing some research on how to join/merge several MTS files into one big file, i stumbled into TsMuxer.
At first the program seemed to be working great since it combined the files into one big m2ts file having the same size as the original seperate ones together.
Unfortunately after playing the file in any player you can think off it only shows the first clip and for example in a 20 min video it just blanks after 3 minutes (the first MTS file)
One interesting thing is that when I play the file in VLC player it spits out a player for every single mts file (hence crashing the program) so the this suggests all mts files are there. Does anyone know why this happens and how to fix it ?
The original files are from a fairly new panasonic HC-V770 and i've used the defaults m2ts muxing settings using the latest version.
Many thanks in advance !
(btw i'm a noob on all this stuff !)
Join MTS files with tsMuxeR
By alberthuber in forum Newbie / General discussionsReplies: 3Last Post: 14th Feb 2016, 15:38 -
tsMuxeR 2.6.16 to merge MTS files: crash with unknown -4
By MrRalph in forum Video ConversionReplies: 0Last Post: 29th Dec 2015, 04:39 -
How to merge multiple .mts files (canon HF) into one single .mts file
By frmsuv2van in forum Video ConversionReplies: 15Last Post: 5th Sep 2014, 21:21 -
Issue with mts files
By narl in forum DVD & Blu-ray WritersReplies: 19Last Post: 17th Sep 2013, 09:14 -
MTS files merged by tsMuxeR can't be play correctly
By SmilingSun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 15th Apr 2013, 20:35
