Hi. My trusty MeGUI can't handle a wmv file. Just doesn't seem to like it. Using AvsPmod, I've been able to script all the trims I want and here's my question (sorry if it's daft): can AvsPmod run the script? According to posts 2 and 3 of this thread:
https://forum.videohelp.com/threads/311912-good-gui-for-avisynth
it can, but I don't see anything in the tabs...
If AvsPmod is not capable then I'd like to try this suggestion of jagabo's:
https://forum.videohelp.com/threads/377869-MeGUI-my-first-use-of-it-and-some-questions?...=1#post2440121
Could someone expand on the actual procedure, please?
My thanks.
Use this version: AvsPmod 2.5.1-build "r452"
http://forum.doom9.org/showthread.php?t=153248&page=58
Within AvsPmod in the Options menu> Associate .avs files with Avsp> restart AvsPmod.
Run the script in Megui, FFMPEG, Mencoder, VirtualDub and any program that supports .avs files.
That's all.Last edited by remanyao; 9th Jan 2017 at 08:52.
Thanks, but I've sorted it out. Using MeGUI's File Indexer on the wmv gave me 'L-SMASH Works' as default. From that point on it was clear there was a problem. So I changed to FFMSIndex and, despite a warning that it's intended for mkv, avi, mp4 and flv, everything went fine.
Quick query on AvsPmod
By pooksahib in forum Video ConversionReplies: 3Last Post: 22nd Jul 2016, 09:24 -
AvsPmod error
By carlmart in forum Video ConversionReplies: 0Last Post: 20th May 2015, 08:30 -
customizng avsPmod
By adom in forum EditingReplies: 0Last Post: 20th Jun 2014, 04:03 -
AVSPmod not loading?
By chowmein in forum Newbie / General discussionsReplies: 8Last Post: 1st Jul 2012, 03:48 -
AvsPmod Seems Less Bright than Final Video
By VideoFanatic in forum RestorationReplies: 13Last Post: 22nd Apr 2012, 16:34
