Have a nice year friends!
I updated to the latest version of PotPlayer and I lost all my settings... and that is s@itty because I have lost many time at the previous version so I can set it up as I want. But even with that, I had export the preset in my previous version... a REG file... I pushed it and import it to my registry but nothing happened!
Please, any ideas?
Thank you in advance!
Results 1 to 11 of 11
PotPlayer is updated very frequently (I would even say, too frequently). That, and a quick look at the changelog should tell you something about the amount of bugs in it!
"The greatest trick the Devil ever pulled was convincing the world he didn't exist." -
Thank you for your answer, yes I know about the frequent updates, I was just wondering how to restore my settings, if you can help me please...
Did you have quick installation selected? If so you should not have lost your settings.
If quick installation wasn't selected then I believe it treats the installation as a new one and overwrites all settings.
Most settings are not held in the registry but within the program folders itself, which is why importing your registry file didn't change anything. -
I had Budman1 the 64-bit version and installed 64-bit again.
darkknight145 but when you want to export all your setting it exports it to this reg file... -
Under General in Preferences, there's an option labelled "save settings to ini file". Is it checked? If it is you can still export your settings to a reg file but adding them back into the registry won't do anything.
If that option is checked there'll be a file called "PotPlayerMini.ini" in the same folder as Potplayer. If it exists you can back it up to save your settings too. If it does exist, the "save settings to ini file" option will automatically be checked. If the ini file doesn't exist, it won't be and the registry will be used.
I don't know if that's got anything to do with the problem in this case but it might help for future reference. -
Always note the BASIC RULE of computing ... Make a B A C K U P !!!
In preferences, there is a 'export current presets' button'... use it often ... :P
PotPlayer downgrades DTS channels and bit depth?
By Zach_N85 in forum AudioReplies: 6Last Post: 19th Dec 2016, 14:08 -
How to move subtitles a bit down in PotPlayer?
By LovePP in forum Software PlayingReplies: 2Last Post: 31st Dec 2014, 09:08 -
PotPlayer settings
By Montmorency in forum Newbie / General discussionsReplies: 12Last Post: 1st Nov 2014, 02:04 -
PotPlayer Subtitle settings
By Zyph in forum Newbie / General discussionsReplies: 0Last Post: 16th Oct 2014, 01:03 -
PotPlayer - How to restore settings via .ini / .reg
By tuco76 in forum Software PlayingReplies: 6Last Post: 2nd Oct 2014, 08:30
