  1. I use to have version 2.51 it had a screen on the wizard helper that you could set the bitrate and you also could see if the file would fit on a 80 min cd. I just upgraded to 2.53 and I went to finish the dvd rip but the screen was not there. Is there a check box that I need to click? or did they take that out?
    localfinesse
    Sep 2001
    New york
    If you are looking for the wizard , it's still there ,,,under Files
