I only need a Sony TRV to capture a bunch of Hi8 tapes I have. My TRV520 died. Is there any difference between the TRV cameras for what I need, which is to just capture video to my Mac? I'm looking at ebay now and would like to go the most affordable route. Would another camera model/manufacturer work for my needs as well?
I would like to get the highest res video to my Mac.
Any guidance would be very appreciated.
thx
Steve
"Highest res video" will be obtained by using the s-video output to an A/D converter and capturing uncompressed or losslessly compressed. If you are using the IEEE1394 connector, you are getting DV-encoded video, which is not the highest resolution possible. A basic D8/Hi8 camera with TBC capability will suffice. Don't pay extra for fancy lenses, effects, etc. that you won't ever use. You will need to look at the spec sheets or manuals to make this determination.
Thanks for this information. I will look into purchasing an A/D converter. Wondering if this is a decent one or if I should go a bit more high end.
https://www.amazon.com/gp/product/B0029U2YSA/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I have about 25 tapes I will be converting and want to ensure I get a decent converter box. -
Search in the Capturing forum and you'll find reviews of this device and many others.
Sony HX-series software comparison
By TheNorwegian in forum DVD & Blu-ray RecordersReplies: 11Last Post: 1st Jul 2015, 11:36 -
Sony DCR TRV 110E
By Dave1960 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Dec 2013, 08:09 -
Best practices for capturing from SONY TRV-355E (Digital8) Handycam to PC.
By WalkToFreedom in forum Capturing and VCRReplies: 4Last Post: 21st Aug 2012, 18:58 -
Analogue to Digital Capabilities on Sony DCR-PC MiniDV Series ???
By darito in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 20th Apr 2012, 22:30 -
Hi8 Firewire Transfer Problems Using Sony TRV-330 to MacBook
By Bill Uvsayl in forum Capturing and VCRReplies: 12Last Post: 20th Mar 2012, 14:35
