I have 3 mkv files that won't play on my Xbox One S.
After using mediainfo I see they have DTS audio. Probably why they wont play.
What media converter can I use to change the DTS to AC3 audio and retain everything else the same?
Results 1 to 11 of 11
I'll give Popcorn a try even though Panda flagged it as virus and deleted it. Will just shut Panda during installation I suppose.
Seems odd to me that it gets flagged as a virus if in fact this prog has been around for years. -
I specified the Source File but the Run button is greyed out.
In the upper section of the same pane it has Common Directory, Individual Locations, Media Info highlighted in red and keeps flashing Media Info missing file specification. -
You may have to install a couple of 3rd party programs read the docs or go to http://www.networkedmediatank.com/showthread.php?tid=20887&highlight=audio+converter and post a help me request.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Not going to use Popcorn. External Audio Tools zip file is screwed up. Not easy to use for a simple thing.
OLED65E6P, I7-4790K, GTX 750 Ti, Win 10 -
Once it's setup it does work very smoothly and with regular updates etc. Maybe then use Pazera Free Audio Extractor
Ended using FormatFactory. Was relatively easy to use for a noob like me.
Has option to "copy" video without re-encoding so it goes super fast. Outputted audio as AAC.
Only having an issue with missing subtitles in one so far.
Thanks for your help and will take a glance at Pazera.OLED65E6P, I7-4790K, GTX 750 Ti, Win 10 -
Here is the Popcorn Audio Converter tutorial on how to set it up with images of the windows etc
.............have not read the entire thread so don't know if they have been suggested but iWisoft video converter [URL="http://www.iwisoft.com/videoconverter/"] and Freemake Video converter [URL="https://freemake-video-converter.en.softonic.com/"] I find simple to use and the latter really does compress the file so as to maximize the number of files burnt to a DVD. Cheers DD
Mkv convert dts sound into ac3
By fits79 in forum AudioReplies: 5Last Post: 5th Jan 2017, 21:41 -
Anyway to convert MKV DTS to AC3 5.1 surround sound?
By Patsfan37 in forum AudioReplies: 24Last Post: 7th Jul 2016, 06:17 -
How to convert AC3 True-HD to DTS ?
By Kernell in forum AudioReplies: 15Last Post: 29th May 2016, 21:42 -
Best/easiest way to convert mkv with DTS 7.1 audio to ac3 audio
By deathcat in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2013, 15:54 -
Convert BD audio from DTS-HD to Dolby 5.1 AC3 without video?
By agent154 in forum AudioReplies: 1Last Post: 5th Apr 2012, 17:19
