How to make hevc encoding fast...
I'm using staxrip...
Sent from my 2014818 using Tapatalk
Use a faster preset for x265. Buy a more powerful CPU with AVX2 support.
Many encoding noobs seem to think that since HEVC means "high effiency video coding" it'll encode faster somehow. It means nothing of the sort. High efficiency here means high efficiency compression algorithms. It'll take longer to encode than AVC in general.
There are no magic codecs, and each new generation of formats/codecs means more of those nice quality settings. I'm of the opinion that you're probably going to get better quality results using a codec which may be technically worse but whose settings you understand. I've seen quite large HEVC video files that obviously were made by people who didn't understand the options. I could have done better using xvid, and I'm no guru.
FFMPEG 12bit hevc encoding
By aniruddh in forum Video ConversionReplies: 14Last Post: 31st May 2016, 03:08 -
HEVC Hardware Decoding/Encoding
By jmdale1984 in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2015, 22:58 -
Queries on HEVC encoding and decoding errors
By ironurn in forum Video ConversionReplies: 1Last Post: 16th Jul 2015, 02:34 -
GPU powered HEVC encoding is here, sort of.
By sophisticles in forum Video ConversionReplies: 15Last Post: 22nd Sep 2014, 11:25 -
Divx HEVC encoder now supports 4k encoding
By deadrats in forum Video ConversionReplies: 8Last Post: 14th Aug 2014, 00:23
